wholdguy
Mowed the yard and then took the Horses Temperature.
wholdguy
The other day rain was in the forecast so I had to hurry up and get the yard mowed.  I spent just under 2 hours to finish up and then I thought of a project I have always wanted to do.  I used the Charger 12 with the Tecumseh HH120 engine.
I have this Fluke IR Temperature measuring tool.  It's good for finding hot bearings, brakes etc.  So I used it to measure the exhaust pipe temp, just in front of the muffler, with the engine at idle.
The temperature measured 565 deg F, and this was just as I finished mowing.  I thought this was interesting to know.  Someday I should meaure the head temperature at the cooling air exhaust side.
G.
Ed Kennell
Wow, that's hot.   I don't have a temp guage, so I don't know what is normal.   I'm sure others will chime in.
clip
I definitely wouldn't want to touch it.
You should adjust the mixture and see how much the exhaust temps vary.
bmsgaffer
I temp'ed my Onan just the other day as I was trying to cure my exhaust paint and wanted to make sure it hit the cure temp...
I read 650 within 10 minutes with only an idle hydro pump for load...
