pacer 3,177 #1 Posted September 25, 2015 What is the "formula" for points setting to advance/retard timing on a KT-17? More open advances, more closed retards? or viceyversy?My C-175 is hard to start giving indications timing is too early. Reckon points opening can help with this or a mechanical setting needed (which I AM NOT familiar with)Its been for sale and have a possible buyer coming to looksee Sat or Sun so needless to say I'd like for it to behave (the engine is in excellent condition and runs really good once started) Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,710 #2 Posted September 25, 2015 KT-17 service manualhttp://www.wheelhorseforum.com/files/file/2049-engine-kohler-kt17-kt19-sm-tp-2043-apdf/Owner manualhttp://www.wheelhorseforum.com/files/file/4131-engine-kohler-kt17-kt19-series-ii-om-tp-2107-cpdf/Garry Share this post Link to post Share on other sites
boovuc 1,090 #3 Posted September 27, 2015 I take the whole engine shroud off and chalk mark the timing mark on the flywheel. Just adjust your points from there to make sure they are on.The KT is a bi#*@ to start if you are losing your prime to your fuel pump. My C-175 does this if it sits longer than two/three days.As long as your fuel shut off isn't bad, try closing it after you run it each time. An inline check valve is also a good idea. If it's hard to start in between runs during the same day, then your points could be the culprit or a bad condenser/weak coil/bad plug wire(s)/etc. :< ) Share this post Link to post Share on other sites
