Brian01 481 #26 Posted September 24, 2015 That's what I'm saying, you can push the brake, it'll stop spinning, take it out of a gear (to put it into another)and it starts spinning again. Belt to tight? Share this post Link to post Share on other sites
Racinbob 11,919 #27 Posted September 24, 2015 (edited) I think your belt is fine. You must have a belt guard on it in order for the belt to stop properly. It sorta guides the clutched belt away from the spinning engine pulley and allows it to stop. It's the same for all Wheel Horses, not just the Suburbans. When you stop but still have it in gear the input pulley is being held and offers enough resistance to stop the belt. Shift to neutral and the pulley freewheels. Edited September 24, 2015 by Racinbob 1 Share this post Link to post Share on other sites
Brian01 481 #28 Posted September 24, 2015 You know where to find one for an RJ 58? There's usually one on EBay, but not now, that I can find anyway, also looked in vendor section here on RS, with no luck. Overlooking it? Share this post Link to post Share on other sites
Racinbob 11,919 #29 Posted September 24, 2015 I sent you a PM with his email. It looks to me like you'll need a Suburban belt guard, not a RJ. RJ's have a flat idler pulley and push the belt down to tighten. 1 Share this post Link to post Share on other sites
Brian01 481 #30 Posted September 24, 2015 Ohh true, yes..duh.. Share this post Link to post Share on other sites
slammer302 2,156 #31 Posted September 24, 2015 yeah ur problem is not having a belt guard my suburban does the same thing but if i idle it all the way down i can get it into gear without grinding Share this post Link to post Share on other sites
Brian01 481 #32 Posted September 24, 2015 I'll try n get one asap. Went to try n have the exhaust done a sec ago but he wasn't there...hopefully just out to lunch. Share this post Link to post Share on other sites
stevasaurus 23,276 #33 Posted September 24, 2015 Here is an option until you get that belt guard. You can bend the wire to funnel the slack in the belt toward the engine pulley. This works great until you find a belt guard. 3 Share this post Link to post Share on other sites
Brian01 481 #34 Posted September 24, 2015 Cool, thanks for the pics This is mind of off subject, but I also need a URL of where I can order some RJ decals Share this post Link to post Share on other sites
slammer302 2,156 #35 Posted September 24, 2015 Redoyouhorse.com or ebay Sent from my XT1080 using Tapatalk Share this post Link to post Share on other sites
Brian01 481 #36 Posted September 24, 2015 Redoyourhorse.com.....I have looked on there several times....just couldn't think of it for some reason lol.Ima do as Steve suggested for now on belt guides.Just don't have the extra $70ish for a belt guard Share this post Link to post Share on other sites
slammer302 2,156 #37 Posted September 25, 2015 That's why I don't have one yet either Sent from my XT1080 using Tapatalk Share this post Link to post Share on other sites
Brian01 481 #38 Posted September 25, 2015 lol...I'm out here in the shop right now, trying to build the "guides" for it 3 Share this post Link to post Share on other sites
Brian01 481 #39 Posted September 25, 2015 Not the prettiest, but so far, is functioning as should... 3 Share this post Link to post Share on other sites
AMC RULES 37,196 #40 Posted September 25, 2015 You need a belt cover. Share this post Link to post Share on other sites
Brian01 481 #41 Posted September 25, 2015 You buyin'? lol Share this post Link to post Share on other sites
Racinbob 11,919 #42 Posted September 25, 2015 As long as you're getting the belt to stop you'll be fine. Well, just watch your pant legs, fingers....... 2 Share this post Link to post Share on other sites
Brian01 481 #43 Posted September 25, 2015 lol yeah, for sure. It's stopping, for now anyway, really need "thicker" guide rods...I use pegboard hangers to build these, they are just a little flimsey. But not bad Share this post Link to post Share on other sites
stevasaurus 23,276 #44 Posted September 25, 2015 Go to ACE or TSC and buy some sturdier rod. Looks like you have them in the right place. They should be about 1/4" away from the belt when the belt is under tension. Looks good Brian and at least you can ride it without hurting that trans. Share this post Link to post Share on other sites
Brian01 481 #45 Posted September 25, 2015 Yep, seems to work okay, now getting a metal gas tank....i took the plastic one and stuck under it for now, but after i get exhaust ran up there, that plastic wont do..the metal one I got with the RJ, it has been welded on bottom.and I also had to JB Weld afew pin holed.....I put gas in it a bit ago and is sitting out there right now...so far, I haven't found any leaks, but the inside is not so clean..Trying to find some kind of acid or something to clean it with...I know all the small engine guys around here say that Toilet Bowl cleaner works great, vinager , etc..I don't have an electrolysis barrel set up yet, so that's not an option. Oh and I've already done the "small rocks inside and shaking the heck out of it" .lolAnd it may be good enough, but I dang sure dont wunt anything sucked up in the carb of that great running motor...Never fails, start first pull almost every time! Share this post Link to post Share on other sites
stevasaurus 23,276 #46 Posted September 25, 2015 Put an inline fuel filter in there. Cheap insurance. Share this post Link to post Share on other sites
Brian01 481 #47 Posted September 25, 2015 Yep, for sure. Should I go with a small one or medium size? Share this post Link to post Share on other sites
stevasaurus 23,276 #48 Posted September 25, 2015 A small one should be good...buy 2 and change it after some time. I think they are as big around as a quarter. Share this post Link to post Share on other sites
Brian01 481 #49 Posted September 25, 2015 Yeah the umm " pancake" type.. Metal tank is installed...ill go get fuel filter in awhile 2 Share this post Link to post Share on other sites
Brian01 481 #50 Posted September 26, 2015 Got the fuel filter put on, and EXHAUST finally ran....should be good to go for now...took it for a cruise around the yard a bit ago...after getting the exhaust on! Much quieter 2 Share this post Link to post Share on other sites
