ishmael1980 1 #1 Posted September 15, 2015 Hey guys. Does anyone have the manual for the 300 Series Easy Twin Rear Grass Bagger (07-11BC01)? Can't seem to find it at the Toro site. Trying to figure out why only one bag is filling and the other is nearly empty.Thanks in advance.Bob Share this post Link to post Share on other sites
cleat 8,747 #2 Posted September 15, 2015 I believe the left side bag fills first then the right side will fill. Level indicator rod is on the right hand side so you know when both are full. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,014 #3 Posted September 15, 2015 Here are the manuals for the one year later baggerhttp://www.wheelhorseforum.com/files/file/3018-mower-rotary-37in-sd-1991-1998-07-11bc02-bagger-easy-twin-om-ipl-snpdf/Garry Share this post Link to post Share on other sites
dcrage 631 #4 Posted September 15, 2015 Cleat is correct -- You need to fill the left bag to the top and then the new debris will bounce off into the right bag -- I usually switch bags when the first one fills -- The left bag packs down more -- Changing sides gets the maximum loading before having to dump Share this post Link to post Share on other sites
ishmael1980 1 #5 Posted September 15, 2015 Great! Thank you guys. Share this post Link to post Share on other sites
MalMac 1,334 #6 Posted September 16, 2015 I don't like Gator blades for mowing grass but they work great on leaves. Found that out when I went to lift one of the bags to dump it. Material is a lot finer and thus a whole lot heavier so it equals more in the bag. Share this post Link to post Share on other sites
