rem722 26 #1 Posted September 12, 2015 Does anybody recommend a engine to repower a 603? Share this post Link to post Share on other sites
slammer302 2,156 #2 Posted September 12, 2015 Kohler k181 Sent from my XT1080 using Tapatalk Share this post Link to post Share on other sites
rem722 26 #3 Posted September 12, 2015 Can you buy a new kohler k181 or similar? Share this post Link to post Share on other sites
Pullstart 68,065 #4 Posted September 12, 2015 look on classifieds, auctions, etc... I was creative enough to find an air compressor powered by the K181T and it went cheap because the tanks were leaking on it. But the engine runs like a top! 1 Share this post Link to post Share on other sites
slammer302 2,156 #5 Posted September 12, 2015 there is still sum nos k181s out their but like pullstart said you can find good used ones too Share this post Link to post Share on other sites
BESTDOGEVER 218 #6 Posted September 14, 2015 Kohler makes a 7 hp that is used on some log splitters it is or was available at tsc it is a good running engine and is ohv so it brings your tractor up to date and still uses a kohler Share this post Link to post Share on other sites
953 nut 62,052 #7 Posted September 14, 2015 If you are buying a used motorized component like a log splitter, chipper etc. be sure that the crank shaft is a straight cut and not tapered. Most direct drive components use a tapered shaft engine. If it is belt driven you are good to go. 2 Share this post Link to post Share on other sites
