fast88pu 3,372 #1 Posted September 5, 2015 Did sunstrand make a 1" axle model ? Share this post Link to post Share on other sites
sorekiwi 761 #2 Posted September 7, 2015 I would have to drag it out from the bottom of the transmission pile that I have, but I am about 99% sure that the trans from an 876 had 1" axles. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,661 #3 Posted September 7, 2015 Curiosity got the best of me.1965 models 875 and 1075 used 1" axles1966 model 876 used 1" axlesGarry 2 Share this post Link to post Share on other sites
fast88pu 3,372 #4 Posted September 8, 2015 ok because I have a horse that I can't figure out the model of. Tags are missing. Has hydro lift a 12hp kohler with electronic ign. Any guesses anyone ? Share this post Link to post Share on other sites
pfrederi 18,856 #5 Posted September 8, 2015 The hydro lift and electronic 12 hp would lead towards an Electro or Charger 12... but not the 1" axles.Is it a hydrogear or a piston to piston?? (The hydrogear motor housing is figure 8 shape the piston is round) Share this post Link to post Share on other sites
fast88pu 3,372 #6 Posted September 9, 2015 Its is the hydro gear style unit Share this post Link to post Share on other sites
pfrederi 18,856 #7 Posted September 9, 2015 I would bet some swapped out a rearend. Is there a spec number on the motor also is it a long or short frame. (What is the wheel base measurement.) Share this post Link to post Share on other sites
fast88pu 3,372 #8 Posted September 9, 2015 Off hand I would say a long frame because it has a hood on it that says C-111 but the tractor is not a C- 111. I think the hood was swapped onto it Share this post Link to post Share on other sites
pfrederi 18,856 #9 Posted September 9, 2015 My bet is a swapped out rear end from one the 875-6 or 1075's listed above into an Electro or Charger12 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,661 #10 Posted September 10, 2015 The following also used 1" axles1972 Charger 10 model 1-04101973 10hp Auto model 1-04701973 10hp Auto model 1-0475 - Piston-piston hydro1974 B-100 Auto model 1-05101975 B-100 Auto model 1-0511Garry Share this post Link to post Share on other sites
