Guest fireman #1 Posted November 20, 2008 Hey All, Is there a better tire pressure when you plow snow? I will be running chains. The new Carlisles say max 22psi in the rear. The manual for the tractor says to inflate to 12psi for normal use. Just wondering if anyone has tried more or less air. As usual :hide: Share this post Link to post Share on other sites
nylyon-(Admin) 7,880 #2 Posted November 20, 2008 I am no expert, but when I put the chains on my 416 I deflated the tires to get them on, then inflated the tires to make the chains tight. To me, I used the tire pressure for the chains, not for traction. Share this post Link to post Share on other sites
Rod(NASNUT) 1 #3 Posted November 20, 2008 I am no expert, but when I put the chains on my 416 I deflated the tires to get them on, then inflated the tires to make the chains tight. To me, I used the tire pressure for the chains, not for traction. I do the same thing also and have good luck :hide: Share this post Link to post Share on other sites
big mike 13 #4 Posted November 20, 2008 Me too....must be follow the leader :hide: Share this post Link to post Share on other sites
wallfish 18,089 #5 Posted November 20, 2008 I have a new paved driveway so I can't use chains, and had to switch to Ag tires. The Ag tires get better traction when the preasure is lower. This may also be the case with chains too, more surface area touching the ground, but probably not as critical. Share this post Link to post Share on other sites
catman81056 3 #6 Posted November 20, 2008 I have a new paved driveway so I can't use chains, and had to switch to Ag tires. The Ag tires get better traction when the preasure is lower. This may also be the case with chains too, more surface area touching the ground, but probably not as critical. Have you checked into the rubber tire chains? They look alittle expensive but might be just what you need. Share this post Link to post Share on other sites
wallfish 18,089 #7 Posted November 21, 2008 Have you checked into the rubber tire chains? They look alittle expensive but might be just what you need. I didn't know they made such a thing. I'll search around or do you have a link where they can be found? Thanks Share this post Link to post Share on other sites
HorseFixer 2,013 #8 Posted November 21, 2008 I have a new paved driveway so I can't use chains, and had to switch to Ag tires. The Ag tires get better traction when the pressure is lower. This may also be the case with chains too, more surface area touching the ground, but probably not as critical. Yep I agree lower pressure to an extent more traction. But not to low as it will take some life off the sidewalls! Share this post Link to post Share on other sites
GlenPettit 1,717 #9 Posted November 21, 2008 I'm thinking just the reverse: More tire pressure would give more traction in snow. The less rubber on the snow and ice puts more pounds/square inch which should equal traction. On a soft lawn you would use less, 8 Share this post Link to post Share on other sites
WheelHorse_of_course 99 #10 Posted November 21, 2008 I'm thinking just the reverse: More tire pressure would give more traction in snow. The less rubber on the snow and ice puts more pounds/square inch which should equal traction. On a soft lawn you would use less, 8 Share this post Link to post Share on other sites
catman81056 3 #11 Posted November 21, 2008 I didn't know they made such a thing. I'll search around or do you have a link where they can be found? Thanks Like I said, they are pricy http://cgi.ebay.com/Rubber-Tire-Chains-23x...1QQcmdZViewItem Share this post Link to post Share on other sites
KyBlue 655 #12 Posted November 21, 2008 man those suckers are pricey... I need to get a set of chains sometime.. its not even turkey day and we've had our first snow.. Share this post Link to post Share on other sites
Sparky-(Admin) 23,147 #14 Posted November 23, 2008 Yep. Dualies are best at giving stabilty and not traction. Mike.......... Share this post Link to post Share on other sites
GlenPettit 1,717 #15 Posted November 23, 2008 WEIGHT, weight, weight: gives a lot of traction, put weight in the tires, and dualies and then you'll get both traction and stability (liquid inside the tire may be best, 80% full). Weight with the front tires will help with steering in snow a lot. Some of us have added 3 Share this post Link to post Share on other sites
