larpa47 23 #1 Posted August 31, 2015 Does anyone know how I would find the original mower blade set number for a WH deck? Is there a listing anywhere? I just restored an 85-36XR01 deck for my B111 and would like new blaeds for it. I've sharpened the ones that were with it but they've seen better days!! Thanks. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,919 #2 Posted August 31, 2015 The blade chart should do ithttp://www.wheelhorseforum.com/files/file/675-chart-blades-and-spindle-cups-rotary-mower-15-pages-492-0392pdf/The 101335 blade set uses blades with a 5/8" x 3/4" double-D center hole. Mentioning that in case your spindle assemblies have been upgraded to the later round hole.Garry Share this post Link to post Share on other sites
doc724 925 #3 Posted August 31, 2015 The double D is an over design. Blades with a regular 3/4 hole will work just fine and are easy to find. However, you may need blades with the two 1/4 dia holes to either side of the 3/4 hole to accept the cast iron collar that goes under the blades. I got mine from Do-Cuts Power Equipment Warehouse. Share this post Link to post Share on other sites
larpa47 23 #4 Posted August 31, 2015 Mine does need the "double-D" plus the two 1/4" holes on either side. So 101335 would be it. Thanks for the prompt replies. Share this post Link to post Share on other sites
