jsp_333 286 #26 Posted September 24, 2015 WHX5The moment you posted option A or B I knew I was doomed.So last night at 10:00 I go out to the garage to get a beer and sit on the rj, I'm thinkin "I gotta try this."Sure enough current(?) generated by K-90 that won't fire is noticeably weaker from K-90 that will.Looks like I'm buying a flywheel puller next week.As always thanks for the help.John Share this post Link to post Share on other sites
WHX?? 55,025 #27 Posted September 24, 2015 good man jsp....pic is worth 100000 words...supporter is the way to go Share this post Link to post Share on other sites
WHX?? 55,025 #28 Posted September 24, 2015 (edited) Fly wheel might come off without a puller but I don't recommend it....thread the nut on flush and hold up on the flywheel ...gently tap on the nut and most times they will come off...best to have a puller tho...specially if yer hooked and more than not yer gonna need it again...Northern tool has a nice set for under $80 Edited September 25, 2015 by WHX5 Share this post Link to post Share on other sites
jsp_333 286 #29 Posted September 25, 2015 Hey WHX5That was solid looking around and finding Northern Tool for me. THANKS!I bought a puller last week but not nearly big enough. 4" tri-jaw I believe.Do I need 6 or 8 inch to get the flywheel off.I'm assuming utube for videos - never attempted this before Away for the weekend - will get that supporter status worked out and get tools and pics next weekCheers, John Share this post Link to post Share on other sites
WHX?? 55,025 #30 Posted September 25, 2015 You a good man John Share this post Link to post Share on other sites
WHX?? 55,025 #31 Posted September 28, 2015 This is the set I have, not real hi test but good enought for hobbyist use.http://www.northerntool.com/shop/tools/product_13315_13315 Share this post Link to post Share on other sites
jsp_333 286 #32 Posted September 28, 2015 Thanks for the link at least now I know I'm buying the right tool.Having pictures makes it so much easier. Couldn't find self-deprecating emoji so you'll have to appreciate the humour as written Share this post Link to post Share on other sites
jsp_333 286 #33 Posted September 29, 2015 Bought a couple of tri jaw flywheel pullers today.There is no way they are going to fit behind the flywheel.I've already tried. And it's not recommended for that type of flywheel.Watched a few utube videos and that whole pry bar sledge hammer thing seems like its for the more experiencedThere are no self taping screw holes on the flywheel for the other kind of gear puller.So how exactly am I supposed to get the thing off.I'll upload photos of the 4 engines tomorrow evening now that I've got my status worked out. Thanks karl. Share this post Link to post Share on other sites
slammer302 2,156 #34 Posted September 29, 2015 I heat up the flywheel and then thread the nut on the crank shaft a little and then give it a wack with a brass hammer the fly wheel usually pops off Sent from my XT1080 using Tapatalk 1 Share this post Link to post Share on other sites
Howie 900 #35 Posted September 29, 2015 I have couple of flywheel removers that are a 1" hex about 1 3/4 long threaded inside, screw on crank to about 1/8" fromFlywheel hit with hammer. I think they were sold by Tecumseh but I use them for whatever engine they will fit. SometimesA pth bar behind flywheel for some pressure.DDavid Share this post Link to post Share on other sites
jsp_333 286 #36 Posted September 29, 2015 Ok Photos at last Share this post Link to post Share on other sites
jsp_333 286 #37 Posted September 29, 2015 So engine two is working.Engine 1 is the focus of this exercise.Currently has week spark hence all the talk of flywheel pullers.Think I'm going to go with the air tool method as it appears to be the most forgivingie. no whackin' flywheel with a hammer.All suggestions are appreciated.I'll try it tonight - maybe even record video of the process Share this post Link to post Share on other sites
oliver2-44 11,214 #38 Posted September 29, 2015 (edited) Instead of a "Jaw" type puller I use the "bolt type puller. I have the one from Harbor Freight, it works for most jobs and you cant beat the price $ http://www.harborfreight.com/bolt-type-wheel-puller-set-69889.htmlOver time I've replaced the bolt that came with it with grade 8 bolts. You flywheel should have 3 or (probable 4) empty threaded holes inside of the fin area. Install the puller on the flywheel, tighten up the center puller bolt against the drive end of the drive shaft (loosen nut first) to put tension on the flywheel. Then give the end of the center bolt a good hit with a hammer. If it doesn't come off tighten genter puller bolt some more (ie more tension) and hit it again.The bolt puller puts the "pull" close to the center of the flywheel while a "jaw" type puller puts the pull on the outer diameter and can have a higher risk of breaking a flywheel,PS I might be interested in some engine parts once you get yours restored! Edited September 29, 2015 by oliver2-44 Share this post Link to post Share on other sites
slammer302 2,156 #39 Posted September 29, 2015 I believe the k90s didn't have the holes for a bolt puller i believe you are supposed to use a knock off tool like Howie is talking about Share this post Link to post Share on other sites
jsp_333 286 #40 Posted September 29, 2015 That's correct no pre-drilled holes. There dosen't appear to be anyway to grip the flywheelAnything special about that knock-off tool. I know I've got something similar.1/2 inch hex (not 1inch) threaded on inside kicking around my photo studioI'll drop by Home Depot tonight and have a look to see if they have the inch hex Share this post Link to post Share on other sites
WHX?? 55,025 #41 Posted September 29, 2015 Nice red in your handle John....let's let them pics fly now!!!! I noticed you have the "shower head" muffler on one of them....save it if you can I hear those are like gold! Share this post Link to post Share on other sites
AMC RULES 37,254 #42 Posted September 30, 2015 You're not referring to the muffler on that green engine? Pictured below is a "shower head" muffler. 1 Share this post Link to post Share on other sites
jsp_333 286 #43 Posted September 30, 2015 Got the flywheel off tonight.Air tool technique worked well for me.So photos of the engine that came with the tractor.This engine has weak spark.Will probably just replace everything.Can I just swap stuff out from the engine in my next post which is known to have good spark So pics of engine with good sparkAnd just to put everyone's mind to rest both green engines came off a bolens walk behind Share this post Link to post Share on other sites
AMC RULES 37,254 #44 Posted September 30, 2015 Yep, swap your parts...to make a runner. Share this post Link to post Share on other sites
WHX?? 55,025 #45 Posted September 30, 2015 Red motor Craig, 2nd pic down, heard those are rarer then hens teeth....Clean the fly wheels up good and make sure there are no particals sticking to the magnets. The one looks like the magnets may have been rubbing on something. I don't know if there is a way to check or adjust the air gap (the distance between the magnets and the coil) on these motors but check the manual. Also check the magnets to be sure the screws holding them on are tight or loctited. Many a good coil have been taken out by loose magnets. Not a bad idea to use some blue loctite on the screws holding the coil down either. Check electrical connections to be clean & tight. Use star washers where needed. Share this post Link to post Share on other sites
WHX?? 55,025 #46 Posted September 30, 2015 Heres the manual for k91 http://www.wheelhorseforum.com/files/file/4104-engine-kohler-k-series-sm-tp-2379pdf/ couldn't find a manual for the 90 but should be real similar to a 91. Maybe some other guys have it? Share this post Link to post Share on other sites
jsp_333 286 #47 Posted September 30, 2015 Thanks, got it last week and printed all 137 pages.Any idea why the first engine pictured has a condenser (?) and the second one doesn't Share this post Link to post Share on other sites
WHX?? 55,025 #48 Posted September 30, 2015 I would guess the condeser is this, just mounted differently unless it is in by the points, I think some of them are there too. Share this post Link to post Share on other sites
jsp_333 286 #49 Posted September 30, 2015 Ya most of the ones I've seen are by the points but boy that looks like a funny place to put a condenser.I also wouldn't think the magnet is deep enough but you never know.I'll try and get into it tonight but time will be tight.Probably just clean and then switch the flywheels and see it I get a better spark.I'm thinking pulling everything off of one and switching it to the other is going to take some time and light Share this post Link to post Share on other sites
jsp_333 286 #50 Posted October 1, 2015 WHX5 was right - pulled it apart last night off sure enough that's where the condenser was - see red arrow in photo above.Today's question; Is the spark plug wire just supposed to pop out of the coil? Pulled two apart last night.Can't see any way to attach it other than just jamming it back in the hole on the coil. There appears to be a spikey thingy at the bottom of the hole but can't see how that would work given the vibrations of a running engine?Thanks to all Share this post Link to post Share on other sites
