callum12 257 #1 Posted August 30, 2015 hi all,I've just purchased a plough for my horse, i will be ploughing a patch of ground that hasn't been touched for a very long time it will also be my first time ploughing. to help me along the way i'd like to find a clear and concise video about how to set up a single furrow plough, or at least a good detailed write up on the setting up. i've had a look but to no avail. any tips and tricks will also be much appreciated.thanks callum Share this post Link to post Share on other sites
AMC RULES 37,236 #2 Posted August 30, 2015 Lots of good Youtube videos on the subject. https://www.youtube.com/results?search_query=how+to+set+up+a+single+bottom+plow 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,762 #3 Posted August 30, 2015 Block the left front and rear tractor wheels up on a flat surface the depth you want to plow. Now lower the plow and adjust so it sets flat on the ground. This is how everything is positioned when the right wheels are in a plowed furrow.If you are not getting the depth you want tip the front of the plow down a bit.If it is going too deep raise the front of the plow a bit. It does not take much of a change to get results.This is called adjusting the suck. By design the plow will pull it's self into the ground.Garry 3 Share this post Link to post Share on other sites
prondzy 3,889 #4 Posted September 1, 2015 Internet search brinly moldboard plow manual. I found a newer manual but the principal still applies. They made the plows they now how to set them up. 1 Share this post Link to post Share on other sites
callum12 257 #5 Posted September 3, 2015 (edited) thanks for the help everyone, I've found some good videos nowand thank you west_ca-(file mod) for the write up, always good to learn the terminology.i've also downloaded the brinly manual.callum Edited September 3, 2015 by callum12 2 Share this post Link to post Share on other sites
C-101plowerpower 1,606 #6 Posted September 3, 2015 lemme get my plowers manual out and scan it inhang on Share this post Link to post Share on other sites
callum12 257 #7 Posted September 4, 2015 @ c-101plowerpower, thank you very much, i think you've got my email if you want to send it that way? callum Share this post Link to post Share on other sites
C-101plowerpower 1,606 #8 Posted September 4, 2015 I think i'll make it an PDF and upload it to the manuals section Share this post Link to post Share on other sites
C-101plowerpower 1,606 #9 Posted September 4, 2015 if only the scanner would work with me Share this post Link to post Share on other sites
C-101plowerpower 1,606 #10 Posted September 10, 2015 still cant get the scanner to work with me so here's some pics 3 Share this post Link to post Share on other sites
callum12 257 #11 Posted September 10, 2015 thank you for going to all the effort, I've saved every picture, i'll probably print them off too when i compile a field manual for my WH!thanks againcallum Share this post Link to post Share on other sites
C-101plowerpower 1,606 #12 Posted September 10, 2015 The book is still available from Amazon, search for tractor plowing at it's best Share this post Link to post Share on other sites
