ronhatch 406 #1 Posted August 25, 2015 What is the best and safest way to remove the 1" stub pipe from a Kohler K-241 block? Share this post Link to post Share on other sites
953 nut 59,737 #2 Posted August 25, 2015 Presuming there is enough to get a pipe wrench on it; use an oxy- acetylene torch to heat the entire diameter of the pipe at the end where it meets the block red hot then turn it out with the wrench. 1 Share this post Link to post Share on other sites
JPWH 6,334 #3 Posted August 25, 2015 I just recently removed one from a K181. The 1" collapsed and broke at the threads when I tried to loosen it with a pipe wrench. Then I used a small chisel to remove the remaining pipe thread from the block. 2 Share this post Link to post Share on other sites
Tankman 3,523 #4 Posted August 26, 2015 I've had a few where the nipple was broken off right at the block.I carefully sabre sawed a slot inside the pipe but not deep enough to slice the block.Then with a drift pin, tap, tap, tap on the pipe until it started to collapse, then when I was able to grap the pipe with vice grips,turn the pipe (it was curling inward) until it collapsed enough to draw it out.Half hour at the most. Clean the threads, vac'd out the block. All is well. 2 Share this post Link to post Share on other sites
rmaynard 16,289 #5 Posted August 26, 2015 (edited) If the pipe is still there, cut it off with a hacksaw or sawzall about 1/4" from the block. Take a small chisel and hammer and collapse the pipe toward the center. Grab it with a pair of pliers and pull it out. I've done it that way at least 4 times. Edited August 27, 2015 by rmaynard spelling 2 Share this post Link to post Share on other sites
Jake Kuhn 1,579 #6 Posted August 26, 2015 The collapsing the nipple method works very good. But be careful doing it. I would recommend heating it and then collapsing it. I ended up cracking a block doing it once and needless to say wasn't too happy at the time. lol Share this post Link to post Share on other sites
Coadster32 793 #7 Posted August 26, 2015 All good methods listed here. Just do yourself a favor, and exercise some common sense. This is a touch-and go feely kind of thing.Tapping doesn't mean BFH. Slitting doesn't mean cutting thru. Heat can be good, but there might be a cost for that transferring a bunch of heat to the block. I wouldn't be surprised if you needed a new head gasket from doing this method. (they are known to go because of exhaust heat as it is.) Just take your time, go easy, and it can certainly be done. 5 Share this post Link to post Share on other sites
DennisThornton 4,771 #8 Posted August 26, 2015 (edited) Lots of good advice and I think Coadster32 summed it up well. I would try red heat first, if that fails slit the pipe with a saw and then with a small chisel and medium hammer tap from all around the outside to the center to gradually collapse as much of the pipe as you can. Then even try to unthread the pipe with the hammer strokes. It might not be instant but you will be able to do it with some patience. Edited August 28, 2015 by DennisThornton rephrased 1 Share this post Link to post Share on other sites
