ronhatch 410 #1 Posted August 25, 2015 What is the best and safest why to remove the 1' stub pipe from a cast-iron K-241 Kohler block? Share this post Link to post Share on other sites
KC9KAS 4,746 #2 Posted August 26, 2015 Lots and lots of penetrating oil 1st. Let it soak.Use a pipe wrench or good channel lock pliers.If it is broke off already, use a hacksaw blade to make a relief cut and a small punch/chisel to bend one side of the cut pipe up. At this point, you should be able to use a needle nose plies to remove the stub.I always use a pipe tap to clean up the threads once the pipe stub is removed.Another method...heat it up with a torch, melt some wax onto/into the threads....use a pipe wrench/channel locks to remove the stub.This method also works with a large "easy-out". Just be careful to NOT drive the easy out into the block! Share this post Link to post Share on other sites
clip 185 #3 Posted August 26, 2015 If you don't have a pipe tap, take a cut-off wheel or hacksaw and cut a vertical slot down the threads in a new 1" pipe nipple, then screw this in like you were tapping a hole. Half to one turn forward, quarter turn back, using cutting oil. It'll act like a pipe tap to clean the threads. Not as elegant, but it'll do in a pinch. 2 Share this post Link to post Share on other sites
