HorseHead1089 100 #26 Posted October 13, 2015 (edited) Well,today I painted the frame and other such, I guess ive finally made it to two pages! Hopefully assembly will take place soon....for the gear drive, the engine pulley is 5.5 inches correct? Because I have to order one for the huge crank on the 20 hp mag. Edited October 13, 2015 by HorseHead1089 1 Share this post Link to post Share on other sites
Ken B 3,203 #27 Posted October 13, 2015 Should be pretty cool when done. But dude, you got no shoes on? 1 Share this post Link to post Share on other sites
HorseHead1089 100 #28 Posted October 13, 2015 (edited) haha, for the shoes part I uassually go take pictures after I'm done working, I don't work without the foot protectors. this whole picture rotation thing bothers me. Maybe one day I will figure out wich way spits them out straight. Edited October 13, 2015 by HorseHead1089 1 Share this post Link to post Share on other sites
mikekot3 93 #29 Posted October 13, 2015 Hello Horsehead,Nice work on the tractor. regarding the picture orientation open the picture in picture viewer and then rotate it to the way you want it and save it again. Share this post Link to post Share on other sites
HorseHead1089 100 #30 Posted October 14, 2015 I've been doing some research on pulleys, and I can't seem to find one with a 3 3/8 bore and the diameter for the gear drive, maybe I can get a 6 inch in there without modding the tins? Any help on tracking down pulleys and pulley size info would be great. Share this post Link to post Share on other sites
HorseHead1089 100 #31 Posted October 14, 2015 Wow... just some snooping around, it looks like the 8 sppeds require a 4 inch not a 5 inch is that correct? I dont know why i thought it was that big, can anyone confirm a 4"? Share this post Link to post Share on other sites
Thor27 892 #32 Posted October 15, 2015 Yes 4". With that said....Require is such a strong word. you could go bigger, especially with a M20. Share this post Link to post Share on other sites
HorseHead1089 100 #33 Posted October 15, 2015 Thanks, now it just down to finding a right size pulley with the right size bore, with setscrews or some sort of separate locking collar? Share this post Link to post Share on other sites
bmsgaffer 2,071 #34 Posted October 15, 2015 I tried to find it, but didnt... What size is the crankshaft on your M20? Share this post Link to post Share on other sites
HorseHead1089 100 #35 Posted October 15, 2015 The crank measures out to 1 3/8 of an inch.And I found a 4 inch with a 1 3/16 bore in the pulley, however it is still to narrow... Share this post Link to post Share on other sites
bmsgaffer 2,071 #36 Posted October 15, 2015 Can you take a stock WH pulley to a machine shop and have it bored and re keyed?a 4" pulley is stock on the 8 speeds but you can use a bigger one, it will just make you go faster... Share this post Link to post Share on other sites
953 nut 70,077 #37 Posted October 15, 2015 Grainger has a 1 3/8 ID X 4 1/4 OD double groove ( # 3X449 ) Go get it! WP37695 Fixed Bore V-Belt Pulley - Grainger Industrial Supply.html WP37695 Fixed Bore V-Belt Pulley - Grainger Industrial Supply.html Share this post Link to post Share on other sites
HorseHead1089 100 #38 Posted October 15, 2015 Right on 953! Thanks for that, I assume a 1/4 inch will not change the need for a stock belt? Share this post Link to post Share on other sites
bmsgaffer 2,071 #39 Posted October 16, 2015 You should be alright, the clutch on an 8 speed helps make up some of the difference if its minimal. Share this post Link to post Share on other sites
HorseHead1089 100 #40 Posted October 20, 2015 Motor Mount has arrived!!! now onto doctoring up the motor and some other odds and ends while i wait for my stuff to get back from the body shop. now back to the Homework... Share this post Link to post Share on other sites
HorseHead1089 100 #41 Posted October 24, 2015 It's been a long week of school, but due to buying parts like a madman I gotta re route time from the 320 to other things like my 10hp K series and some craftsman I picked up for cheap to sell later. Well that's in the shop today so I guess that's the first order of business. I also mounted up the motor plate on the 320, I can already see that 20hp bulging out the side of the narrow hood. Share this post Link to post Share on other sites
HorseHead1089 100 #42 Posted October 24, 2015 Quick question before I go get more parts, what is the easiest way to strip paint from a carb, or do you guys prefer painted carbs? Share this post Link to post Share on other sites
bds1984 1,519 #43 Posted October 25, 2015 I've used the gallon can of carb cleaner one can find from most auto parts stores. It comes with a basket that you can set parts inside to soak. I've submerged entire carburetors in it and allowed them to soak for a few hours before I was able to take a nylon brushe to clean off the paint on the carb body. 1 Share this post Link to post Share on other sites
Thor27 892 #44 Posted October 30, 2015 Is that a NEW motor plate? Partstree? Share this post Link to post Share on other sites
HorseHead1089 100 #45 Posted October 30, 2015 Yes it is, no one felt like selling one on ebay and I didn't feel like making one so I just bought a new one. It's bolted down with brand new Shiney stuff I'll get a picture tonight. Also bought this on sale 6/12v with auto charge rate and float maintainer/trickle charge has wheels and range of options from sears I throw some more pictures up of this as well. Share this post Link to post Share on other sites
HorseHead1089 100 #46 Posted October 31, 2015 Well that's the brand new motor mount, and there are more pics of the new battery charger. Also that 10hp K series is currentley up for grabs if someone feels like making an offer. 1 Share this post Link to post Share on other sites
Aldon 4,834 #47 Posted October 31, 2015 Looking good so far. New parts are nice luxury on occasion.Looking forward to seeing the 320-8 finished Share this post Link to post Share on other sites
HorseHead1089 100 #48 Posted November 3, 2015 Yeah me too, it may take a while because he offered to do it for way less than full price if I didn't need it done right away and I could wait after some of his higher pay jobs got finished. Share this post Link to post Share on other sites
HorseHead1089 100 #49 Posted November 17, 2015 Ok, so in the pto of a wheel horse, there is a sleeve, that goes over the crank, and under the needle bearing of the pulley cone, what steel is that made out of, I'm looking to have it turned or order a new piece of metal stock for the oversize crank of the m20, I figure it would be easier to try this than to immediately rip the crank from the motor and turn and re key. Share this post Link to post Share on other sites
HorseHead1089 100 #50 Posted February 4, 2016 Well 4 pages deep and several months since an update, I bet you guys thought I gave up! Nope, in fact it's been real exciting. That quick flip of a craftsman turned into an engine rebuilding nightmare and that was not fun. I have yet to sell that sorry piece of machinery. On the 320 front, we have the parts sandblasted and painted from the shop done, and now ready to put back together. As far as the motor, no progress has been made on it since I have had barley anytime to work at all! Now I have her resting on all fours and I just need some cotter pins and other hardware. This has been quite an interesting build so far! 4 Share this post Link to post Share on other sites
