snowhound 106 #1 Posted August 22, 2015 Can a mowing deck that was on a D series be mounted on a 400 series?Ed Share this post Link to post Share on other sites
daveoman1966 3,884 #2 Posted August 22, 2015 (edited) yes.... without question, You MAY need to swap over or procure a few parts of the lift hardware on the deck. The two front upright 'stanchions' are the main difference. Edited August 22, 2015 by daveoman1966 1 Share this post Link to post Share on other sites
rexman72 210 #3 Posted August 22, 2015 I actually was going to try to swap the 48 inch mowing deck from the D to the 417A Share this post Link to post Share on other sites
tbarnhart 240 #4 Posted August 23, 2015 Not a direct fit as mentioned, but it will work after changing a few pieces of the mounting brackets. Everything should bolt up-no holes to drill. My C-160 had a d-series deck under it when I first got it. I think it was the original deck that came with it from new. The brackets were probably changed by the dealer. The deck/spindles/pulleys/etc. are all the same. Share this post Link to post Share on other sites
