snowhound
Mower mounting D to 400
snowhound
Can a mowing deck that was on a D series be mounted on a 400 series?
Ed
daveoman1966
yes....  without question,  You MAY need to swap over or procure a few parts of the lift hardware on the deck.  The two front upright  'stanchions' are the main difference.
Edited by daveoman1966
rexman72
I actually was going to try to swap the 48 inch mowing deck from the D to the 417A
tbarnhart
Not a direct fit as mentioned, but it will work after changing a few pieces of the mounting brackets. Everything should bolt up-no holes to drill. My C-160 had a d-series deck under it when I first got it. I think it was the original deck that came with it from new. The brackets were probably changed by the dealer. The deck/spindles/pulleys/etc. are all the same.
