austin gill 0 #1 Posted August 21, 2015 Ive seen alot of talk on axle seals and them being very cheep at $6.00 but i have a wheel horse B-80 that just started leaking gear oil badly and was wondering if anyone could kindly help me on whare to get a seal?? thank you..Austin Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,283 #2 Posted August 22, 2015 Napa is one place that supplies SKF or Chicago Rawhide (CR) seals. Once you find the original seal number there are lists pined at the top of this transmission section that will change the part numbers over. Axle diameters are 1" and 1-1/8" so make sure you get the correct one. Post again if you need more help.Garry Share this post Link to post Share on other sites
stevasaurus 23,715 #3 Posted August 22, 2015 You either have 1" or 1 1/8" axles...1" axles use SKF 9815.....TORO # 1008631 1/8" axles use SKF 11050....TORO # 100443Like Garry said...NAPA or Motion Industries or your TORO dealer. There is usually a reason they start leaking, make sure your bearing is OK by checking for up and down or side to side play. You should have very little to no play. 5 Share this post Link to post Share on other sites
Racinbob 12,996 #4 Posted August 26, 2015 Search the number on Ebay. I just bought 6 SKF 9815's for $15.00 shipped. 2 Share this post Link to post Share on other sites
