ziggyswheelhorse 1 #1 Posted August 14, 2015 Any body know what the part number is for a hydro filter is and what oil should I use? Sent from my XT1080 using Tapatalk Share this post Link to post Share on other sites
shallowwatersailor 3,222 #2 Posted August 14, 2015 It uses 10W-30 motor oil. I use Mobil 1 10W-30 synthetic in my tractors. I would use a NAPA 1410 filter in place of the Toro filter. It has flats on the end that makes it easier to remove. 1 Share this post Link to post Share on other sites
ziggyswheelhorse 1 #3 Posted August 14, 2015 OK thanks is there a seal kit to reseal the deck lift valve and the hydro? Sent from my XT1080 using Tapatalk Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,519 #4 Posted August 14, 2015 I believe the part numbers in this manual have changed but the last time I checked Toro still had them.http://www.wheelhorseforum.com/files/file/45-lift-hydraulic-valve-and-cylinder-sm-810242r3pdf/Check them here. If priced should be available from any Toro dealer.http://www.partstree.com/parts/A well established hydraulics shop should also have them.Garry Share this post Link to post Share on other sites
