fast88pu 3,376 #1 Posted August 11, 2015 I have two single stage blowers that I have to put new cables on for the chute rotation. Can anyone tell me the length and size cable I would need for each ? And second question is how do you wind the cable around the crank to get the right rotation left and right ? thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,263 #2 Posted August 11, 2015 If you have the drum or spool on the crank rod this manual explains the cable installation.http://www.wheelhorseforum.com/files/file/40-snowthrower-42in-1978-86-42st01-om-iplpdf/The drum or spool was first used in 1975.Garry Share this post Link to post Share on other sites
fast88pu 3,376 #3 Posted August 11, 2015 thank you I will give that a shot Share this post Link to post Share on other sites
