dsoly 2 #1 Posted August 10, 2015 Hi all, currently working on a 416h, and the pto lever vibrates to the disengaged position. Looked at diagrams and can't figure out why it won't stay locked. Any ideas would be appreciated. Share this post Link to post Share on other sites
boovuc 1,090 #2 Posted August 10, 2015 I would loosen it up. I over-adjusted PTO's in the past trying to make sure they were tight. When this is done, the PTO lever doesn't come all the way down and would flip back up after a minute or so.If this is not the case and you have a lot of vibration, you may want to look at the bearings in that PTO. 1 Share this post Link to post Share on other sites
Don1977 605 #3 Posted August 10, 2015 Check the snap ring on the out side of the short shaft attached to the loop. If it's out of the groove there isn't and pressure on the clutch and this will make the PTO handle loose. Share this post Link to post Share on other sites
dsoly 2 #4 Posted August 10, 2015 I'm trying to picture what your saying don, do u mean on the bottom by cotter pin? Share this post Link to post Share on other sites
Don1977 605 #5 Posted August 10, 2015 I'm trying to picture what your saying don, do u mean on the bottom by cotter pin? The shaft has a snap ring each side of the front bearing on the PTO pulley and attached to the center of the loop. Share this post Link to post Share on other sites
dsoly 2 #6 Posted August 10, 2015 Thanks boovuc,gonna check it out. Share this post Link to post Share on other sites
dsoly 2 #7 Posted August 10, 2015 Thanks Don and Boovuc. I found the snap ring on outer bearing gone... And pto shaft is beat up... May be time for a new bearing and snap rings thank guys 1 Share this post Link to post Share on other sites
