daveoman1966
What PULLEY is this? ? ?
daveoman1966
I have 3 of these NEW pulleys and I know they are either Wheelhorse or Toro but...for the life of me...I can't identify them. It is a DOUBLE-BELT pulley for the CENTER spindle of a 3-blade mower deck and is SLIGHTLY SMALLER dia than the 110148 pulley of 42" decks.  It is 5/8" SMOOTH BORE (no keyway) SMALL pulley is 3 1/2" dia and the LARGER pulley is 4 1/2" dia.  The double-belt pulley is like # 110148 (42" decks   3 3/4 x 4 3/4 pulley), but with smaller pulleys.
Any help out there.....? ? ?
My direct email is here:
DAVEOMAN@WINDSTREAM.NET
can whlvr
I just picked up a 1976c160 8 speed with a 48 side discharge,it has that pulley on it but im not sure if it belongs or not,the deck is rough and has missing parts,i wondered ir it was for driving a grass or leaf vaccum
gwest_ca
Could it be a 109991?
Garry
daveoman1966
No.  # 109991 is for a 36" deck and the top / bottom pulley diameters on that item are within 1/8" of each other, if not the same diameter.
The DOUBLE-BELT  pulley I have in question is 3 1/2" dia and the other is 4 1/2".
Theroundhousernr
I could be wrong but I beleive a friend of mine said the 5xi series deck uses a pulley like that. Just a wild guess because I never seen one. But I remember him talking about it because he needed one.
WNYPCRepair
I saw a 522xi this weekend, the RH pulley had a double pulley on top that was empty. We assumed it was for a bagger.
Lagersolut
Thought I had it figured out but I don't , my 315-8 has the vac bag  set up with a double stacked pulley on the right spindle to drive the impeller/fan that blows the grass back to the bags .   they're both the same diameter - 3 1/2 inches  top and bottom .
Theroundhousernr
This would be the center drive pulley on the deck of the 5xi
