Dual Drive Horse 6 #1 Posted August 5, 2015 I have seen several posts regarding the seals on the lift valve for the GT14. Most claiming they are just square section o rings, which the originals are not, they are proper shaped cylinder seals.This leaves me with several questions.Does anyone have a UK supplier of said seals, as all the hydraulic places round here can't supply?Have ther been any problems using square section o rings instead?If O rings are OK, where to buy them as nowhere I have phoned can get them, and that includes the local hydraulic places?The only Wheelhorse part numbers I can find are for the 520 valve which is a completely different animal, and so far finding pictures of the correct one are proving impossible. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,769 #2 Posted August 5, 2015 The part numbers in this service manual have been superseded but the last time I checked all were still available from Toro.http://www.wheelhorseforum.com/files/file/45-lift-hydraulic-valve-and-cylinder-sm-810242r3pdf/You can check availability herehttp://www.partstree.com/parts/If they come up priced Toro still has them.Garry Share this post Link to post Share on other sites
Dual Drive Horse 6 #3 Posted August 6, 2015 Have checked that manual before, and it doesn't cover the valve fitted to any GT14s I have seen. If I find a part number I can get it if it's still available as we are Toro agents. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,769 #4 Posted August 6, 2015 Here is an older manual.http://www.wheelhorseforum.com/files/file/1231-lift-hydraulic-valve-and-cylinder-sm-810242r1pdf/Garry Share this post Link to post Share on other sites
