alswagg 128 #1 Posted August 4, 2015 i have a few D 180's. Two I have 48" mower decks. The "ugly" d has turf tired and mows great never a problem. The other is a 180 with a 20 hp Kohler with 26" ags. The problem with this tractor the left tires hits the mower wheel sometimes very hard almost runs over the little wheel. The mower is installed correctly but the clearance from the ags to the mower wheels is very close. Say 1/4" to 1/2" max. Does anyone else have problems with mower clearance while using ag tires? I want to keep the ags as I also use this tractor with the 54" grader blade. Oh I am running liquid in the tired with 5 psi of pressure. Same as ugly d with turf tires. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,919 #2 Posted August 4, 2015 Have you ever switched mowers/tractors to see if the problem follows the mower?Garry Share this post Link to post Share on other sites
alswagg 128 #3 Posted August 4, 2015 I should have mentioned that. Yes I have switched mower decks. Plus tried a third. It just seems like the 26" ags are larger than the 26" turfs. If the mower deck was wider the problem would be non existent. Share this post Link to post Share on other sites
pacer 3,179 #4 Posted August 4, 2015 Tire mfgrs seem to sometimes just guess at the size, with differences of maybe 2" in different given sizes. Take a measurement of your 2 tires and compare, just might be they are different sizes. I have 4 D's with 3 having the 48" decks and have never had a problem. 1 Share this post Link to post Share on other sites
