linklaw 0 #1 Posted August 3, 2015 Hi all. I am a brand new member with a question about my mower deck. I have a C145 with a 42" rear discharge deck. My tractor has the hydraulic lift and when I lift up the deck, the left rear edge of the deck runs into the left rear tire. The deck is much closer to the left rear tire than the right rear tire when the deck is in the down position. I looked for an adjustment to move the deck around its center axis to even out the space between the rear of the deck and the rear tires but so far I can't figure it out. Does anyone have any ideas? I took the deck off and do not see any bent or damaged pieces and no cracks in the deck. Thanks.John Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,014 #2 Posted August 3, 2015 (edited) Make sure you have the fork positioned correctly over the upper rod in the quick hitchGarry Edited August 3, 2015 by gwest_ca 1 Share this post Link to post Share on other sites
linklaw 0 #3 Posted August 3, 2015 Garry,Thanks for the quick reply. I do have the fork positioned with the opening over the rod. John Share this post Link to post Share on other sites
doc724 925 #4 Posted August 3, 2015 The older RD decks had a separate metal piece on the back that deflected the grass downward. This piece was, by design, made to extend further out the back on one side than the other. Since I sold my 36 inch RD, I cannot recall which side it extended on. Newer decks do not have this piece. Share this post Link to post Share on other sites
Racinbob 12,802 #5 Posted August 5, 2015 I figured Garry hit the nail on the head. Now it's baffling. Pictures might help us out. Share this post Link to post Share on other sites
linklaw 0 #6 Posted August 5, 2015 I will snap a few pics and post them. I looked closer at it last night and it looks like everything is straight and put together like it should be.John Share this post Link to post Share on other sites
jackhammer 550 #7 Posted August 6, 2015 Just a quick check , are you in the correct lift slot on the deck lifter??Rick Share this post Link to post Share on other sites
linklaw 0 #8 Posted August 9, 2015 Rick,The lift rod is in the elongated slot in the bar attached to the deck. I am thinking that the one side of the deck is being lifted too high. I played around a little with the lift stops but did not correct the problem. I looked at the deck while my son was raising and lowering it and it moves back as it is raising. I took a few pics and will post them. John Share this post Link to post Share on other sites
linklaw 0 #9 Posted August 9, 2015 (edited) Here Are some pics of the deck as it sits relative to the rear tires in the up and down positions. When the deck is raised, it contacts the left rear tire. If you all need different pice please let me know. Thanks. John WH4.JPG WH3.JPG WH2.JPG WH1.JPG Edited August 9, 2015 by linklaw needed to attach pics in correct format Share this post Link to post Share on other sites
shallowwatersailor 3,220 #10 Posted August 9, 2015 I can't open your pictures. Share this post Link to post Share on other sites
linklaw 0 #11 Posted August 9, 2015 Here are a few more pics. WH8.JPG WH7.JPG WH6.JPG WH5.JPG Share this post Link to post Share on other sites
shallowwatersailor 3,220 #12 Posted August 9, 2015 (edited) Is your front mounting shaft #1 rotating? Sometimes they rust and are stiff. That could make the deck move back when lifted. It should lift straight up. Edited August 9, 2015 by shallowwatersailor Share this post Link to post Share on other sites
Racinbob 12,802 #13 Posted August 9, 2015 Something has happened with the pictures John. I can open them but have to do it manually now.Linklaw, that shows us the problem but I was hoping to get a shot of the brackets, etc. hooked up to the tractor. That could be what's causing the problem. Share this post Link to post Share on other sites
squonk 45,591 #14 Posted August 9, 2015 If someone has messed with the linkage on the deck, one or more of the bushings may be missing. Share this post Link to post Share on other sites
shallowwatersailor 3,220 #15 Posted August 9, 2015 I can open the Jpegs. I agree that it is in the linkage which is why I am thinking the front lift shaft. Share this post Link to post Share on other sites
linklaw 0 #16 Posted August 9, 2015 Shaft #1 is loose and turns freely. In fact, it is so loose I had to hold it in place when lifting the deck to hook up the tach-o-matic. I will make sure it is rotating when lifting the deck. I will also snap a few pics of the linkage today and post them. John Share this post Link to post Share on other sites
Racinbob 12,802 #17 Posted August 9, 2015 I was leaning that way too John but the fact that it's just the left side makes me think something could be damaged or, at Mike mentioned, missing. We were typing at the same time Linklaw. Do post more pics before we take more guesses. Oh....you're John too........... Share this post Link to post Share on other sites
linklaw 0 #18 Posted August 9, 2015 Gents,Here are some pics of the deck linkage. I raised the deck up and down and noticed that Shaft #1 does not rotate as the deck raises and lowers. If the deck is disconnected, it moves freely. Hope these pics shed some light on the problem. I had to delete the earlier photos to be able to post these. Thanks all. John Share this post Link to post Share on other sites
Racinbob 12,802 #19 Posted August 9, 2015 It won't pivot John. The side arms pivot on it as you raise and lower the deck. Good pictures but I'm not seeing the problem. Everything looks correct. Now I'm wondering if it's in the deck itself. Am I missing something guys? Share this post Link to post Share on other sites
shallowwatersailor 3,220 #20 Posted August 9, 2015 The front shaft tang is not locking on the release bar in the first photo. Share this post Link to post Share on other sites
Racinbob 12,802 #21 Posted August 9, 2015 I'm not following John. Are you talking the fork? It's straddling the correct rod. Or locking the pivot levers in place? Looks correct for that style to me. Share this post Link to post Share on other sites
shallowwatersailor 3,220 #22 Posted August 9, 2015 (edited) It's #8 in the drawing, and it looks like the "guide fork" is behind the capture hitch rod. It should be on it Edited August 9, 2015 by shallowwatersailor Share this post Link to post Share on other sites
Racinbob 12,802 #23 Posted August 9, 2015 Could be. I'm thinking it looks right. Linklaw, check it out. You have two rods 'captured' by the tach-a-matic side plates. One is the spring loaded rod to release and secure the pivot arms. The other has the pivot arms welded on and it's that rod that the fork straddles. The nomenclature is a killer here Share this post Link to post Share on other sites
pacer 3,179 #24 Posted August 9, 2015 I think sailor may have it ... looks that way to me also, the 'fork' is 'forked' to the small rod. Hope thats the case, its a quick enough fix! Share this post Link to post Share on other sites
Racinbob 12,802 #25 Posted August 9, 2015 Apparently I'm still not seeing it. This fork, right? It sure looks like it's straddling the correct rod to me. Also the angle of the tabs outside the hitch that connect to the two side bars is spot on (last two pictures). Share this post Link to post Share on other sites
