Geochurchi 3 #1 Posted August 2, 2015 (edited) Hi All, is the a right way to install a 79-3061 blade on a Wheel Horse tractor, the manual says to mount the curved piece so it's facing inside,I don't see how it can be mounted any other way, unless it's mounted upside downjust curious .Geo Edited August 2, 2015 by Geochurchi 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,919 #2 Posted August 2, 2015 Blades have been known to get mounted upside down resulting in poor performance from new blades.Think it is just a reminder for the installer. For those that don't do it too often they may turn the deck over to work on it. I can see it getting confusing.Garry 1 Share this post Link to post Share on other sites
boovuc 1,090 #3 Posted August 2, 2015 I take a black magic marker and before I remove the blades for sharpening, I mark which side was facing down. When installing a new blade, just compare it to the old blade and how it was marked. 3 Share this post Link to post Share on other sites
KC9KAS 4,745 #4 Posted August 2, 2015 A small engine repair shop owner once told me....."While tightening the bolt...if you slip off you will cut yourself on the sharp edge"......BUT I just sharpened a couple of blades and re-installed them. Using the information afore mentioned, the left blade was installed upside down.Upon further inspection, I found that the blades turned opposite of each other, making the "cut yourself" idea incorrect for the left blade! 1 Share this post Link to post Share on other sites
Don1977 605 #5 Posted August 2, 2015 A small engine repair shop owner once told me....."While tightening the bolt...if you slip off you will cut yourself on the sharp edge"......BUT I just sharpened a couple of blades and re-installed them. Using the information afore mentioned, the left blade was installed upside down.Upon further inspection, I found that the blades turned opposite of each other, making the "cut yourself" idea incorrect for the left blade! Might be he never saw a geared deck. 1 Share this post Link to post Share on other sites
KC9KAS 4,745 #6 Posted August 3, 2015 A small engine repair shop owner once told me....."While tightening the bolt...if you slip off you will cut yourself on the sharp edge"......BUT I just sharpened a couple of blades and re-installed them. Using the information afore mentioned, the left blade was installed upside down.Upon further inspection, I found that the blades turned opposite of each other, making the "cut yourself" idea incorrect for the left blade! Might be he never saw a geared deck. That was my guess! Share this post Link to post Share on other sites
Tankman 3,526 #7 Posted August 3, 2015 (edited) Acquaintance, not too smart, purchased a new "Deere" me. Haven't seen it yet but, hear tell $1900 from a dealer.His deck, three blade, was leaving a stripe, needed to overlap making a second cut.Duh, one blade was installed upside down.Dealer says, "Decks are shipped pre-assembled. We just hang 'em." Wow! Unbelievable. My decks are removed, set on horses for winter service; blades sharpened or replaced, spindle belt, grease, paint 'n patch (if needed). Edited August 3, 2015 by Tankman 1 Share this post Link to post Share on other sites
WNYPCRepair 1,923 #8 Posted August 3, 2015 My decks are removed, set on horses for winter service; I would need a gantry crane... Share this post Link to post Share on other sites
Tankman 3,526 #9 Posted August 3, 2015 (edited) My decks are removed, set on horses for winter service; I would need a gantry crane... Me too! I always get help setting the decks on saw horses. Always! Edited August 3, 2015 by Tankman Share this post Link to post Share on other sites
Tankman 3,526 #10 Posted August 3, 2015 My decks are removed, set on horses for winter service; I would need a gantry crane... Me too! I always get help setting the decks on saw horses. Always! I might add, Lowes is just down the road from me. I often ride over with grandsons and a hardware list.If available we use stainless hardware and always use Never-Seez. Share this post Link to post Share on other sites
wrightorchid 261 #11 Posted August 3, 2015 I use an impact wrench to remove them, but tighten by hand. I don't have to block the blades, and don't risk the hand wrench slipping. The nuts tend to tighten with use, so don't over tighten. Very important to use grease, or a never seez on them. Share this post Link to post Share on other sites
