kudzu3 323 #1 Posted August 1, 2015 Not really a problem, just a curiosity, but I always have to choke my 1970 raider 10, tecumseh to crank it, even when warm. Just wondering if anyone else has to do this and what would cause it. I'm thinking weak fuel pump (?) but not sure. Share this post Link to post Share on other sites
stevasaurus 23,565 #2 Posted August 1, 2015 (edited) I have 2 ten horse Kohlers, and I do that with both of them. You are able to turn off the choke after starting, right? Mine crank a little slow at first and then get up to speed...I don't know why, but I would say it is common with the 10 hp Kohlers. Edited August 1, 2015 by stevasaurus 1 Share this post Link to post Share on other sites
kudzu3 323 #3 Posted August 1, 2015 Thanks Steve. Yea, immediately after it hits, I push the choke in and all is well. As I said, this is not a problem, just a curiosity. Share this post Link to post Share on other sites
stevasaurus 23,565 #4 Posted August 1, 2015 You may be right. I am thinking that if I took the time to spray a touch of starting fluid down the carb, she would pop with out the choke. 2 Share this post Link to post Share on other sites
WNYPCRepair 1,924 #5 Posted August 1, 2015 Well, horses don't get coffee, so they need a little extra shot of fuel to get going. 3 Share this post Link to post Share on other sites
MalMac 1,334 #6 Posted August 2, 2015 I have some tractors that are the same way and I have a couple you don't have to choke at all at first start up. These tractors are just like real horse's they all have their own personality. Some bite, some don't, some kick , some don't, some are just plain mean, some nice and gentle. 3 Share this post Link to post Share on other sites
Don1977 605 #7 Posted August 2, 2015 Nature of the beast. Some need choke every time you start and some don't. As long as it starts don't worry about it. 1 Share this post Link to post Share on other sites
stevasaurus 23,565 #8 Posted August 2, 2015 Ya, but the road apples all look alike. Share this post Link to post Share on other sites
953 nut 63,897 #9 Posted August 5, 2015 The Tecumseh and Kohler engines both have a mechanical compression release built into them to make them easy to crank over, the down side is that this also results in lower vacuum on the intake stroke. Since our carburetors require a great deal of air flow through the venturi to draw fuel from the float bowl into the compression chamber the reduced air flow requires a little human intervention, we need to pull the choke. I you are running a little on the rich side you may not need to. 6 Share this post Link to post Share on other sites
doc724 925 #10 Posted August 5, 2015 Rich, nice explanation. I never even thought about the effect of ACR. Share this post Link to post Share on other sites
Pullstart 68,741 #11 Posted August 6, 2015 Between grand parents, the in-laws and myself, we've got quite the handful of predator engines from Harbor Freight. Same with those, some pieces of equipment require the choke every single time and some never require. And the most drastic differences are on the engines both bought in the same day! Share this post Link to post Share on other sites
Coadster32 793 #12 Posted August 6, 2015 Every engine likes what it likes. I consider it to be personality. Share this post Link to post Share on other sites
stevasaurus 23,565 #13 Posted August 8, 2015 I knew about the ACR on the "K" series, but for some reason it just takes a few more Amps to get her turning. It is probably my 4 year old battery not fully charged. She cranks good right off the bat if I put the 10 Amp charger on it for a while. I still have to choke it when it has set for a while. They do start without the choke if they are warm...like they should. 1 Share this post Link to post Share on other sites
kudzu3 323 #14 Posted August 8, 2015 Wow, I just keep learning stuff. Share this post Link to post Share on other sites
stevasaurus 23,565 #15 Posted August 8, 2015 Wow, I just keep learning stuff. I know...I learn something every day. Sometimes it makes me mad to do that. I'd like to think that maybe, just maybe, I could get though one day in my life without learning something...but then I would learn that I got through one day without learning something. Dang it. This is an "original...the world according to Stevasaurus" quote. 2 Share this post Link to post Share on other sites
MikesRJ 558 #17 Posted August 9, 2015 Strange. The 10hp Kohler I just rebuilt required choke every time before the rebuild, it even required choke after the rebuild. Even when I got the points mechanically timed and the carburetor tuned, it still required choke. But, when I used a timing light and re-tuned the carburetor, it no longer needed choke to start. Funny how that works out. 1 Share this post Link to post Share on other sites
squonk 45,346 #18 Posted August 9, 2015 (edited) My C160 & RJ require no choke and throttle no matter what. My 73 12, and Power King needs the choke and no throttle. 704 & 1267 need choke and 1/4 throttle. All are Kohlers. My 2 cycle Teckys require an occasional kick in the hind quarters. Edited August 9, 2015 by squonk 2 Share this post Link to post Share on other sites
