MambaJack 0 #1 Posted August 1, 2015 I have recently replaced a broken deck belt for a 314-8. It lasted a couple of hours until, i saw a big puff of smoke and it broke in half again. Any ideas what could cause it to break. The previous belt wasn't actually broken, but pretty skinned up and when i took off the deck was no longer on the correct spot on the pulleysAny help would be greatly appreciated.dave Share this post Link to post Share on other sites
squonk 45,588 #2 Posted August 1, 2015 Check the deck bearings and pulley alignment. Share this post Link to post Share on other sites
Lane Ranger 11,814 #3 Posted August 1, 2015 The bar the idler pulley is on can be worn and the nylon washers underneath it too. The misalignment of the idler bar can cause belt damage too. Squonk's post is also correct if the bearings and pulleys are worn out they will not turn, lock up or run out of proper alignment. Share this post Link to post Share on other sites
Don1977 605 #4 Posted August 1, 2015 What size deck do you have? Share this post Link to post Share on other sites
MambaJack 0 #5 Posted August 1, 2015 I believe the deck is 42" Share this post Link to post Share on other sites
Don1977 605 #6 Posted August 1, 2015 The 42" decks also have had cracking around the spindle mounts that cause the pulleys to not be line up. 2 Share this post Link to post Share on other sites
MambaJack 0 #7 Posted August 1, 2015 Let me go take a photo of it, don' t know if that would help or not Share this post Link to post Share on other sites
daveoman1966 3,882 #8 Posted August 1, 2015 Best longevity comes from OEM belts. However, even a low-grade after-market belt should last more that a couple hours. The belt is PROBABLY dragging on a frozen (stuck) pulley...spindle pulley, the idler on the deck, or an idler on the mule drive. It MAY be due to failure of the spring-tension action of the flat idler pulley bar. If it doesn't 'FLOAT' properly, the belt might flop around loosely ...dragging on some other-wise ok pulleys. Share this post Link to post Share on other sites
