morphemus 0 #1 Posted August 1, 2015 Hi guys i don't know if this is the rigth name for the switch but it is located on the back of the PTO clutch lever inside the battery compartment on my C-161 1978 single cylinder ... anyways i over did it with a wire brush and brushed it to pieces lol so where can i find the right name for it and where can i find one for sale in the UK Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,011 #2 Posted August 1, 2015 Welcome to the forum.8-speed parts listhttp://www.wheelhorseforum.com/files/file/3585-tractor-1978-c-161-8-speed-da-tipl-snpdf/The wiring is on the 8th pageAuto transmission parts listhttp://www.wheelhorseforum.com/files/file/3584-tractor-1978-c-161-auto-da-tipl-snpdf/The wiring is on the 14th pageUse a site like this to see if a part number is still available from Toro. If it is it will be priced.http://www.partstree.com/parts/A used switch from another UK member is another possibility. Post in the Euro Classifieds Wanted section.Garry 1 Share this post Link to post Share on other sites
doc724 925 #3 Posted August 1, 2015 Those switches are available but they are really expensive. Last I looked it was $64 in the USA. I researched and I think either Eaton or Cutler Hammers is the manufacturer, but they are special order only. I picked up a used one from Joe's Outdoor Power (in the US) for about $14. As Garry said, the best bet is a used one from another UK member 1 Share this post Link to post Share on other sites
morphemus 0 #4 Posted August 3, 2015 Thanks guys the parts list i'll go through that.... and i'll try the euro wanted section and look for a UK member or someone willing to post to the UK .... Share this post Link to post Share on other sites
morphemus 0 #5 Posted August 3, 2015 Don't know if its me but i've just downloaded and gone through them parts lists and i can't see it or the part number Share this post Link to post Share on other sites
doc724 925 #6 Posted August 4, 2015 The PTO interlock switch for my C141-8 is 104680. They are $56.60 (US) from Jack's Small Engine in the US. As you already know, they are not easy to install and my experience is that you have to remove the thin blade actuator which rides on the PTO cam, then install the switch and then re-pop rivet the actuator in place. I got mine in OK, but I do not have the switch positioned properly (maybe not enough preload on the button actuator) so effectively the switch does not work as a safety cutout when the PTO is engaged and you get off the seat. Share this post Link to post Share on other sites
morphemus 0 #7 Posted August 9, 2015 Hi doc724 does this mean the tractor still runs without the switch being there? only mine is in bits being built so has yet can't test it going to put up some photos soon just need this switch and some rear wheels as far as i can see so far thats missing terry Share this post Link to post Share on other sites
doc724 925 #8 Posted August 9, 2015 I have to leave to go cycling soon, so not much time to compose this. The tractor runs with the switch in place, but mine will not shutdown the engine with the PTO engaged. However, i think that you can jumper around the switch. Download an electrical service manual from RS to get the wiring diagrams. Then you can see how the switch is wired jumper accordingly. Just remember, once you bypass it, the engine will not shutdown when the PTO is engaged Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,011 #9 Posted August 9, 2015 Here is the wiring diagram you can downloadhttp://www.wheelhorseforum.com/files/file/62-tractor-1978-c-series-kohler-powered-wiring-detailedpdf/Garry Share this post Link to post Share on other sites
morphemus 0 #10 Posted August 9, 2015 Thank you doc724 and gwest-ca i'll have a go at the jumping of the wires looks abit technical for me but i'll give it ago it's only till i can get hold of a switch ..... so i'm still wanting a switch if you guys on here come across one Share this post Link to post Share on other sites
