ScottCT 15 #1 Posted August 1, 2015 I have a 37" sd deck that I know has clearance issues with most tractors with 8" front wheels but I was wondering if anyone either has tried or knows if it would work on a 520 with the swept forward front axle?Thanks for the info.... Share this post Link to post Share on other sites
bmsgaffer 2,069 #2 Posted August 1, 2015 It should fit, but you wont be cutting full width of the rear wheels. I think they are about 40-42". So if smashing uncut grass is an issue for you, then it wont fit. If thats not a problem then go for it! 1 Share this post Link to post Share on other sites
ScottCT 15 #3 Posted August 1, 2015 (edited) Thanks, I only use the 37" deck with the bagger for leaf cleanup in the fall so it shouldn't matter how wide it is. I have two other 42" decks that I use for mowing. Edited August 1, 2015 by ScottCT Share this post Link to post Share on other sites
