canam1991 2 #1 Posted November 16, 2008 Does anyone have pics of a cable routing for the chute turning handle? :D Share this post Link to post Share on other sites
wallfish 18,428 #2 Posted November 17, 2008 Thread the cable through the hole in the drum on the crank first, then turn the the drum a couple of times while holding the cable tight. Connect both ends to the clamps on the far side of the chute while keeping the cable kind of tight. The cable stays under the small hook guides. Mine has a motor attached in place of your handle but it still works the same way. Clamp on chute. There is also one on the inside for the other end of the cable There should be a couple more wraps on my drum but the cable broke and it's a little short. Hope this helps Share this post Link to post Share on other sites
