rracioppi 2 #1 Posted July 30, 2015 (edited) So I am almost done putting everything back together I decided today I would give the engine a try even though I have no hooked up everything, I put a jump box on the positive and grounded the negative to the frame, the engine turns over strong and I see gas in the filter problem is no spark, I pulled the plug and nothing? Not really sure where to start could it be not having a good ground? Edited July 30, 2015 by rracioppi Share this post Link to post Share on other sites
boomers_influence 106 #2 Posted July 30, 2015 rryou COULD state what engine.thank you boomer Share this post Link to post Share on other sites
rracioppi 2 #3 Posted July 30, 2015 K301 on a wheel horse c121, nothing is really grounded yet no battery installed just hooked up the jumper to the positive and the frame it turns over strong but no spark? Share this post Link to post Share on other sites
oldredrider 2,553 #4 Posted July 30, 2015 Hook a jumper wire from positive battery post to + side of coil and see if that gives you fire. Share this post Link to post Share on other sites
rracioppi 2 #5 Posted July 30, 2015 Just hooked a jumper to positive battery to Positive coil and no spark Share this post Link to post Share on other sites
oldredrider 2,553 #6 Posted July 30, 2015 Try cleaning and resetting you points gap. 1 Share this post Link to post Share on other sites
rracioppi 2 #7 Posted July 30, 2015 just made sure they were .020 I never touched them and it ran when I got it. so that is not it. Share this post Link to post Share on other sites
oldredrider 2,553 #8 Posted July 30, 2015 Points will become oxidized. ..the nature of bare metal. CLEAN them with a points file or fine sandpaper. 1 Share this post Link to post Share on other sites
rracioppi 2 #9 Posted July 31, 2015 Thanks Paul I will I guess you are leaning towards the points, Share this post Link to post Share on other sites
WNYPCRepair 1,924 #10 Posted July 31, 2015 To clarify, everything is connected as normal on the tractor, and you are connecting jumper cables to the positive battery cable and ground at the frame? Or do you mean you are connecting the positive jumper cable to the starter? Share this post Link to post Share on other sites
boovuc 1,090 #11 Posted July 31, 2015 The C-121 has a battery ignition. Before you start jumping through hoops, hook the battery up and all the other connections including safety switches if you didn't do so already. Make sure the connectors are clean and not corroded. And your battery needs to be fully charged to make sure that isn't the issue. 3 Share this post Link to post Share on other sites
rracioppi 2 #12 Posted July 31, 2015 Thanks for the replies I will add some more information since I slept on this I think I have an idea of what it is but not how to fix it. I have the wiring harness in the tractor but not one of the safety switches are connected to anything in fact none of them were even in working order when I took it apart most were corroded beyond saving, now I am only using this tractor for plowing Ii have no deck so not really interested in having all the interlocks working would rather bypass all of them? I think the one stopping me from getting spark is the seat interlock? I am thinking I need to complete the circuit any help you guys can give is appreciated. Share this post Link to post Share on other sites
rracioppi 2 #13 Posted July 31, 2015 I know have power to the coil with the safety switch for the seat pressed but still no spark, are thereothers I need to bypass? Share this post Link to post Share on other sites
pfrederi 19,809 #14 Posted July 31, 2015 If you have 12 volts at the coil and no spark time to clean the points and if that doesn't work replace the condenser Share this post Link to post Share on other sites
rracioppi 2 #15 Posted July 31, 2015 Thank you I am doing that exact thing, how can I tell how many volts at the coil? I have an ampmeter but no idea how to use it except to see if there is power? Share this post Link to post Share on other sites
pfrederi 19,809 #16 Posted July 31, 2015 Are you talking about the ammeter on the tractor or do you have a separate one? How do you know you have power at the coil. Share this post Link to post Share on other sites
rracioppi 2 #17 Posted July 31, 2015 I have a small meter hand held but no idea what to set it on? Also are there any other interlock switches that would prevent a spark or are they for the starter? The starter engages fine I am holding the saftey swich closed and putting the positive on the coil positive and grounding the negative wand Share this post Link to post Share on other sites
pfrederi 19,809 #18 Posted July 31, 2015 Doesn't your meter have a DC voltage setting? Anyway the safety switches block or allow current to the coil and some block or allow current to the starter solenoid. If she cranks and IF you have voltage to the coil but no spark the issue is not safety switches. Share this post Link to post Share on other sites
rracioppi 2 #19 Posted July 31, 2015 OK thank you I am getting new points and new condensor next Share this post Link to post Share on other sites
pacer 3,179 #20 Posted July 31, 2015 By hooking 12v directly to the + on the coil (and grounding) you eliminate ALL safety switches, lights. ignition switch, etc. If you dont get spark then it can only be - coil, condenser, points, spark plug/wire or the wire from coil to points (I had this one happen) How are you checking for spark? My method is, with it hooked up direct and the cover off the points I use my finger and manually open/close points and see if it get spark there at the points, if so then points, condenser and coil are good. (If checking spark at plug make sure the plug is grounded) Share this post Link to post Share on other sites
rracioppi 2 #21 Posted July 31, 2015 OK new points and condensor in and it sparks and started up great then the starter started sparking and now it wont work at all, UGH did I burn the starter out?? Share this post Link to post Share on other sites
pfrederi 19,809 #22 Posted July 31, 2015 Sparking from where?? Motor (Which end) or the solenoid.?? Does the pinion gear disengage from the flywheel after it starts? Share this post Link to post Share on other sites
rracioppi 2 #23 Posted July 31, 2015 OK, I think the cowling was rubbing so I put another screw in it and now this thing starts up great, dont know why it would not go but may be a ground the stator is sparking so I have to mount everything next Share this post Link to post Share on other sites
pfrederi 19,809 #24 Posted July 31, 2015 The stator is under teh flywheel is it sparking???? Share this post Link to post Share on other sites
rracioppi 2 #25 Posted July 31, 2015 so I meant the piece that is in front of the battery mounted and has a 3 prong attachment I think it charges the battery, it is not sparking it is grounding on the tractor and creating a spark because it is not bolted down thats all, Share this post Link to post Share on other sites
