Thurman71 5 #1 Posted July 24, 2015 Forgive the stupidity here. But, this is the first Horse I've owned or worked on. It is giving me fits with running. I have been through entire fuel system. Except fuel pump. It runs fine for a few minutes. Then, goes down hill fast. i have been leaning towards an ignition problem. Can anyone tell me. If, this model still has points and condensor? Or, if it has a module under the flywheel. And, if it has points. Are they under the flywheel also? It has the 16 horse Onan engine. And, ran perfect last week. Now. is another story. Thank you for any help or info anyone can provide. Share this post Link to post Share on other sites
Ed Kennell 41,422 #2 Posted July 24, 2015 (edited) It sounds to me like it is running out of fuel. Pull the fuel line off at the carb and hold it in a container while you crank the engine over. If you get a good strong spurting of fuel, your fuel supply to the carb is OK. Will it run if you feed fuel with a squirt bottle directly into the carb. If it runs , then you have a carb problem. Could be the float is sticking partially closed or there is a hole in the float. Edited July 24, 2015 by ekennell Share this post Link to post Share on other sites
Thurman71 5 #3 Posted July 24, 2015 It runs fine as long as the deck is not engaged. I can drive around uphill, downhill no problem. When deck is engaged for just a few minutes. It starts spitting and sputtering. And, will die at times. That's why I was leaning towards an ignition problem. Just had carb off and apart. Cleaned all passages and bowl. But, have not checked for fuel flow amount. Bowl was full when disassembled. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,393 #4 Posted July 25, 2015 Here are some manualsWiringhttp://www.wheelhorseforum.com/files/file/1020-tractor-1988-516-h-wiring-detailedpdf/Partshttp://www.wheelhorseforum.com/files/file/2165-tractor-1988-500-series-auto-iplpdf/Servicehttp://www.wheelhorseforum.com/files/file/2162-tractor-1988-516-h-518-h-smpdf/Enginehttp://www.wheelhorseforum.com/files/file/6-engine-onan-p216-p218-p220-p240-sm-492-4006pdf/Garry Share this post Link to post Share on other sites
Thurman71 5 #5 Posted July 25, 2015 Can definitely use some of this info. Thanks. Threw in the towel for today. But, I have to get it figured out somehow. Way to much yard to use push mower on. I'm just stumped. I've never worked on an onan. And, its got me whipped at the moment. Share this post Link to post Share on other sites
Ed Kennell 41,422 #6 Posted July 25, 2015 If it runs fine with the PTO disengaged, You probably don't have a fuel problem. If it only misses and stalls when you engage the PTO, I would look at the PTO, seat, and neutral safety switches. Maybe a loose or bare wire or a switch that is failing with the additional vibration of the deck. Share this post Link to post Share on other sites
Thurman71 5 #7 Posted July 25, 2015 I know I don't have a problem with the seat switch. It's been bypassed. The neutral safety switch, I have to push over with my finger to get it to start. But, have not checked on PTO switch. So, it is a possibility. Everybody has been giving me things to look at. Thanks a bunch. And, please feel free to keep the ideas coming. I will look into every one. Until I find the right one. Share this post Link to post Share on other sites
Thurman71 5 #8 Posted July 25, 2015 You guys are awesome. Thank you for all the ideas. Got that monster up and running. It was a combination of 2 things. PTO switch dirty and not working correctly. And, part major dork on my part. Put too much seafoam in not enough gas. . I will take my lumps for that any day. When it makes fixing that easy in the end. 2 Share this post Link to post Share on other sites
bmsgaffer 2,052 #9 Posted July 26, 2015 Haha, im guilty of the seafoam thing before too.Put a load of it in the tank then forgot to fill the tank back up. They dont run too well on straight seafoam. 1 Share this post Link to post Share on other sites
Ed Kennell 41,422 #10 Posted July 26, 2015 Glad to hear the sick horse is cured. 1 Share this post Link to post Share on other sites
Thurman71 5 #11 Posted July 26, 2015 Made my wife very happy too. She's the one that wanted it to begin with. And, actually likes running it. So, I gotta keep momma happy. Share this post Link to post Share on other sites
