JPWH 6,542 #151 Posted February 28, 2016 3 hours ago, Aldon said: I've never done the electro tank thing. Would a soak in the tank remove the rest seizing it together? If line of sight allows it will. It seems to work pretty well up to a half inch total thickness. At least that is what I have experienced so far. 2 hours ago, 953 nut said: Another option comes to mind; some time ago Ed Kennell did a post about pulling a stuck hitch pin. He drilled a few holes in the gap between the pin and the transmission case and put PB Blaster in the drilled holes, that allowed deeper penetration. give it a try and if it works you owe @ekennell a royalty for his patented technique. Thanks for the info I will try that and if it works I hope @ekennell's royalty is within my means. 1 Share this post Link to post Share on other sites
Ed Kennell 43,795 #152 Posted February 28, 2016 Not to worry Hank. The only payment we need is a report on what worked when that wheel finally surrenders. 2 Share this post Link to post Share on other sites
DennisThornton 4,772 #153 Posted February 28, 2016 E-tank rust removal is like plating in that the process is dependent on the direction of electron flow and somewhat "line of sight". To make matters worse, where the penetrants did their work, they also hinder water from entering and therefore the rust removal process. Better E-tank first, penetrant after. Or HEAT the sucker and drive it off. I do like the idea of a small pilot hole between the shaft and collar! Going to remember that! (I hope...) 2 Share this post Link to post Share on other sites
JPWH 6,542 #154 Posted February 28, 2016 (edited) I'm almost ready. I ran out of welding rods but most of it is tacked up. Edited February 28, 2016 by Hank01 Add picture 3 Share this post Link to post Share on other sites
Retired Sparky 526 #155 Posted February 28, 2016 (edited) 27 minutes ago, Hank01 said: I'm almost ready. I ran out of welding rods but most of it is tacked up. That's an awesome looking press. I have no doubt you will win in the end. Edited February 28, 2016 by Retired Sparky 1 Share this post Link to post Share on other sites
JPWH 6,542 #156 Posted February 28, 2016 (edited) I got the tie rods repaired today. Other than the rust they are in excellent shape so I wanted to use them instead of buying or making new ones. A little mig welding and grinding they came out pretty good. Edited February 28, 2016 by Hank01 Spelling 8 Share this post Link to post Share on other sites
Ed Kennell 43,795 #157 Posted February 28, 2016 A little welding???? That is an awesome job. 3 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,499 #158 Posted February 28, 2016 First class job, as everything has been turning out. Thumbs up. Glenn 3 Share this post Link to post Share on other sites
DennisThornton 4,772 #159 Posted February 28, 2016 2 hours ago, Hank01 said: I got the tie rods repaired today. Other than the rust they are in excellent shape so I wanted to use them instead of buying or making new ones. A little mig welding and grinding they came out pretty good. Holy crap! I'm going to start sending some of my stuff to you! Ya did good, but something you might want to consider next time... Those rust pits, well, craters, really didn't weaken them to where there's a strength issue. You could have filled those with autobody filler, or something like AlumaLead if you wish, sand and finish. I bought a cast vise and was surprised that someone cared enough about it's looks to fill in some voids with autobody filler. Looked great but didn't hold up to some of my pounding! Metal filled epoxies, metal fillers or similar could be used as long as they aren't expected to add strength, just fill the voids. 1 Share this post Link to post Share on other sites
AMC RULES 37,250 #160 Posted February 28, 2016 I applaud the fact that someone... cared enought to fill 'em with metal. 2 Share this post Link to post Share on other sites
DennisThornton 4,772 #161 Posted February 28, 2016 Just now, AMC RULES said: I applaud the fact that someone... cared enought to fill 'em with metal. Indeed! I was impressed! " Holy crap! I'm going to start sending some of my stuff to you! Ya did good " 1 Share this post Link to post Share on other sites
Aldon 4,828 #162 Posted February 28, 2016 If it's worth doing, it's worth the time to do it 1st class! Its a disease or something. Once you get started on a restoration, it's really hard to fight the urge not to go 1st class if time, talent, materials etc are realistic. At least it is for me. Whenever I am tempted to save a buck or take a short cut, I always end up going back and redoing. For or me it's a bit of a problem. Can't seem to do less. For me, restoring is another level beyond repairing. Excellent job Hank. Your setting the bar high:-) 3 Share this post Link to post Share on other sites
JPWH 6,542 #163 Posted February 28, 2016 I don't like to use filler on anything more than 1/16" and less if possible. Im still working on my filler skills. That is why you dont see a completed hood yet. Thanks for the kind comments. 1 Share this post Link to post Share on other sites
DennisThornton 4,772 #164 Posted February 29, 2016 Thick fillers are not always taboo. Large flat flexible panels, auto/truck hoods, roofs, deck lids and even the center of large flat panel doors and thick fillers don't do well together. Panels flex and the thick fillers don't, so it cracks. It's just too much in the wrong place! Nothing wrong with filling a non-structural area that doesn't flex with a filler. It's like filling a drywall hole, or a knot hole in a board. Fillers aren't bad just too often abused. 2 Share this post Link to post Share on other sites
Retired Sparky 526 #165 Posted February 29, 2016 Holy Crap is exactly my thoughts. You guys of 'extreme talent' never cease to blow my mind. Keep up the good work. But you don't really consider it work, do you??? 2 Share this post Link to post Share on other sites
JPWH 6,542 #166 Posted February 29, 2016 (edited) It really is fun to repair the neglect that this has had to endure but sometimes it is work. Something that is hard to some is easy to others. Edited March 1, 2016 by Hank01 1 Share this post Link to post Share on other sites
JPWH 6,542 #167 Posted March 2, 2016 I got the lift assembly apart and ready to blast. I had to work on the brake lever. I don't know what could have caused this. I have had to repair, replace or replace and repair every part so far except the cast parts. To date I have purchased from RS members: Seat Tool box and fenders Transmission mushroom gear Tire paint that I haven't used yet Flea bay: Motor tins S/G belt cover Choke and throttle cables S/G rebuild kit Other sources: All new transmission bearings and seals 3 Share this post Link to post Share on other sites
Aldon 4,828 #168 Posted March 2, 2016 (edited) These restorations can nickle and dime you into the poor house! Edited March 2, 2016 by Aldon 2 Share this post Link to post Share on other sites
JPWH 6,542 #169 Posted March 2, 2016 The way I look at it is I'll have a good working tractor and at less than half the cost of a cheap big box lawn mower. It will do anything I want it to do and I know it is mechanically sound because I will have gone through every inch of it. The bonus will be I will have a tool box and fenders left over to use on the modifications on my Raider that is my go to all purpose worker. I will be going through the Raider the same way when I complete the 854. 4 Share this post Link to post Share on other sites
JPWH 6,542 #170 Posted March 6, 2016 The battle of the steering wheel is over. A little drilling, soaking, and about three pumps after contact with my homemade steering wheel press. 9 Share this post Link to post Share on other sites
DennisThornton 4,772 #171 Posted March 6, 2016 I'm pretty sure most of that was accomplished by the third pump! Funny, your first posting had that steering wheel prominently in the middle of the picture. Perhaps your first picture of the "After" will do so as well? One battle after another my friend? I think that's fine as long as you're the winner and I'm sure that's going to continue! "Steering wheel won't come off so he builds a press just for that! Yep! He's going to win!" 3 Share this post Link to post Share on other sites
Phil854 130 #172 Posted March 6, 2016 Amazing job on the tie rods!!! 2 Share this post Link to post Share on other sites
Pullstart 68,529 #173 Posted March 11, 2016 Great progress Hank! I've been away for a while so it's great to "binge" catch up! Not like it helps now, but sometimes I've learned to use candle wax as a quencher with rusted stuck stuff... HEAT it red hot like Dennis is talking about, then feed it the butt end of a chunk of wax and it'll pull it in just like solder and copper sweat joints. 2 Share this post Link to post Share on other sites
DennisThornton 4,772 #174 Posted March 11, 2016 I've read about using heat and candle wax and keep intending to try it. Several say it works pretty well. 1 Share this post Link to post Share on other sites
JPWH 6,542 #175 Posted March 11, 2016 The steering wheel I have was once a chew toy in its life so I figure I could try about anything without damaging a good steering wheel. What I discovered was heat will melt the plastic before it gets the metal hot enough. The plastic becomes soft at about 150 degrees and starts melting about 200 degrees. I think drilling holes at an angle to get penetrating fluid down deep then using a press is the best method for me. I have been working on the damage I caused with the heat as well as the dog teeth impressions. I will say the plastic welder ha sure come in handy. 3 Share this post Link to post Share on other sites
