JPWH 6,542 #26 Posted July 29, 2015 Well after some more clean up and tearing apart the differential I have decided to build it with all the old parts. After this practice run I should be ready to do a total rebuild with all good parts. I may have to buy one but would prefer to use what I already have. I have another compete trans and my son has another that is already torn apart.My plan is to build the trans and the motor while paint is curing on tins and frame. The gas tank looks to be the next major hurdle. 2 Share this post Link to post Share on other sites
motor12 367 #27 Posted August 10, 2015 I rebuilt the trans in my RJ58 and it was in worse shape than yours. It's a little noisy but works fine. 2 Share this post Link to post Share on other sites
JPWH 6,542 #28 Posted August 11, 2015 My son has a transmission tore down that I hope to get some of the parts from. If the gears are in better shape I will try to repair one of these. I won't risk it if I don't have a replacement. I will be going to visit week after next. I'm also going to go salvaging in his parts yard. Never know what goodies I might find. lol 2 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,516 #29 Posted August 11, 2015 Watching you redo yours reminds me of when I redid mine. Your going deeper into it, I didnt have to split the trans. Keep up the fine work, I have to watch this one through to the end. Most folks luv these little 854s, I do. The end product will have you smiling ear to ear.Glenn 3 Share this post Link to post Share on other sites
JPWH 6,542 #30 Posted August 15, 2015 (edited) Thanks for all the encouragement. this will be my first total teakardown and rebuild. I want to make sure it is done well. I have made a little more progress. I got detained because I had to do a little upgrade on my electrical system. Started blowing fuses so I added a couple 240 volt circuits and replaced the old fuse box. Now back to the fun stuff. I had finally started on the blast cabinet. I will start a new thread for the build.I have totally tore down the starter/gen and ordered new studs.I need to find a new bolt. One was rounded off. Edited August 15, 2015 by Hank01 4 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,516 #31 Posted August 15, 2015 Hank, your doing great. My opinion would be to keep this thread for the teardown & rebuild, why not? Its allready up an running. But that up to you. If you look around this site I think thats how most are done. Best of luck.Glenn 2 Share this post Link to post Share on other sites
JPWH 6,542 #32 Posted August 15, 2015 Thanks.I am keeping this thread. I will start a new thread for the blast cabinet build. 1 Share this post Link to post Share on other sites
JPWH 6,542 #33 Posted August 29, 2015 (edited) My visit to see my grandchildren paid off. I got to spend an afternoon at Chucky Cheese with 4 precious children. One of which I have only seen in pictures for 6. years. I am a very happy grandpa. I also got almost all the transmission parts I needed. I have one gear oñ the way from a RS member. I also got a new shifter. I have new bearings and gasket ordered as well as shifter retaing bolt.And I also have a starter gen kit I received last week.I found a guy through a friend that is removing the broken screws frim the gas tank and will repair the bottom plate and bead blast it. I should be able to pick it up next week. Edited August 29, 2015 by Hank01 5 Share this post Link to post Share on other sites
JPWH 6,542 #34 Posted September 5, 2015 Gas tank as removed and attempt to remove screws. A total of 8 broke off so I took it to a shop for repair. repair did no go as planned. After much consideration ànd weighing the pros and cons this is what I have 1 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,516 #35 Posted September 5, 2015 Hank, get some PB blaster and soak stuff long before you go near it to take it apart. It helps. Btw, looks great, you took it down WAY BETTER than I did mine, well done. Matter of fact, looking at yours, well sir, I might have to redo mine. Lolglenn 1 Share this post Link to post Share on other sites
JPWH 6,542 #36 Posted September 5, 2015 Hank, get some PB blaster and soak stuff long before you go near it to take it apart. It helps. Btw, looks great, you took it down WAY BETTER than I did mine, well done. Matter of fact, looking at yours, well sir, I might have to redo mine. Lolglenn Other than the gas tank I have only broke 3 bolts. I've had everything soaking for a couple months. It was so rusty I had to tear it totally down and find better pàrts. As soon as I finish my blast cabinet I will be ready to start cleaning tins, frame and wheels. I don't get much shop time and when I do I work with all the neckbreaking speed of a ruptured turtle.lol 3 Share this post Link to post Share on other sites
JPWH 6,542 #37 Posted September 26, 2015 I've been collecting parts while working on the blast cabinets. Got a few parts blasted today. Hopefully I'll get some quality shop time this weekend. 4 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,516 #38 Posted September 26, 2015 Your rolling along at a nice clip. Loaded for bear.glenn 1 Share this post Link to post Share on other sites
JC 1965 1,534 #39 Posted September 26, 2015 Lookin good, keep the pics coming. 1 Share this post Link to post Share on other sites
JPWH 6,542 #40 Posted September 27, 2015 Got a few more parts blasted today which just added to my work load. I need to add a transmission mounting plate. There are no cracks but some deep pits that have weakened the plate. I took some time to work on the locked up 1533 bearings. Lots of pb blaster, patience, and TLC. In Good news they are actually in decent shape. Spin free and smooth. 4 Share this post Link to post Share on other sites
JPWH 6,542 #41 Posted October 11, 2015 I finally got a little more shop time. After blasting the front wheels I discovered the rust was worse than I thought so I had to do a little repair. While I had everything out I decided to repair the seat I acquired from a red square member as well. I always make sure I don't leave anything smoldering after welding and grinding so I sprayed some primer while I waited. 4 Share this post Link to post Share on other sites
Aldon 4,832 #42 Posted October 11, 2015 That's some significant rust through. You hve your work cut out for you.I would be be tempted to look at replacements. 3 Share this post Link to post Share on other sites
JPWH 6,542 #43 Posted October 11, 2015 Believe me I thought about it. Once I got started it only took a couple hours. If I run across some at a good deal I may replace them later. 1 Share this post Link to post Share on other sites
AMC RULES 37,254 #44 Posted October 11, 2015 (edited) Think I've read, for that nasty rim rust through...some people opting to use JB Weld with good results too. Your repairs look perfect, great work Hank. Edited October 11, 2015 by AMC RULES Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,516 #45 Posted October 12, 2015 Hank, your doing great in my opinion. Those rims scare me, but I am no metal guy either. Probably a snap for you.glenn 1 Share this post Link to post Share on other sites
JPWH 6,542 #46 Posted October 13, 2015 Thanks guys the seat came out good but I still have more to do on the rims. It's so humid here in mid GA that I had to protect them from rusting again till I could get more play time. I will blast and finish repairs one at a time. 2 Share this post Link to post Share on other sites
RedRanger 1,470 #47 Posted October 16, 2015 You got more patience than I do. I'd scrap those in a heartbeat. 1 Share this post Link to post Share on other sites
JPWH 6,542 #48 Posted October 16, 2015 I have a couple more sets of wheels but they just don't look quite right. I'm not going for an all original restore but these wheels just look right to me. I look at it as a labor of love. Good thing too because this whole tractor needs LOTS AND LOTS of TLC. 4 Share this post Link to post Share on other sites
AMC RULES 37,254 #49 Posted October 16, 2015 It's a good thing Hank...that found you. 1 Share this post Link to post Share on other sites
mikekot3 93 #50 Posted October 17, 2015 Those rusted wheels are Not safe at all !!! 1 Share this post Link to post Share on other sites
