chorusguy 227 #1 Posted July 18, 2015 (edited) Finally got a push blade. But I have questions. 6-2132First thing. I had a really hard time getting it mounted. So any tips for that would be great. Second I have both solid links the straight one with the offsets and the curved one. The diagram shows a straight one so that is the one I used. Is that correct? Third what do you do with the deck lift bar? Fourth I mounted the solid lift in the second hole if the rocker and in the slot on the a frame. Correct? And finally when u am lowering the blade about mid way the tractor twists slightly so something is binding. I think it us the mower lift arm but am by myself so i can't see. And now really finally the motion control arm is binding slightly on something. Any suggestions? Mounted on a c160 auto Edited July 18, 2015 by chorusguy submitted before I was done typing. stupiid phone Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,057 #2 Posted July 18, 2015 Your blade is a 1975 model and we do not have that manualIn 1974 the blade came in 2 packages and here are the manualshttp://www.wheelhorseforum.com/files/file/2474-blade-dozer-42in-1974-6-2131-om-iplpdf/http://www.wheelhorseforum.com/files/file/2857-blade-dozer-42in-1974-6-4114-a-frame-om-iplpdf/Here is the 1981-84 manualhttp://www.wheelhorseforum.com/files/file/52-blade-dozer-42in-1981-1984-06-42bc02-om-tiplpdf/1984 was the year the blade width went from 42" to 48" with this modelhttp://www.wheelhorseforum.com/files/file/1986-blade-dozer-48in-1984-1989-06-48bc01-om-tiplpdf/Garry 1 Share this post Link to post Share on other sites
varosd 1,185 #3 Posted July 18, 2015 Some better pictures of mounting the blade. pictures courtesy of other RS members. 3 Share this post Link to post Share on other sites
chorusguy 227 #4 Posted July 18, 2015 (edited) OK. Thanks for your replies. I noticed in the photos there is a chain mounted through a trunion and then a smaller solid link. Both ate mounted to the mower deck lift. That would work. I don't have the chain but do have the smaller solid bar. However using a chain doesn't provide any down force correct? Edited July 18, 2015 by chorusguy misspelling Share this post Link to post Share on other sites
Racinbob 12,844 #5 Posted July 18, 2015 Correct, no down force with a chain. I always hooked mine up directly to the lift rock shaft so I could get the down force. 1 Share this post Link to post Share on other sites
squonk 45,775 #6 Posted July 18, 2015 Down force is good if you have a paved driveway, but if you don't your driveway will end up in your yard! I use a chain from the trunion all the way to the plow with no solid link. I have a stone drive and use the dial a height adjustment to hold the plow about an inch above the surface to keep the stone movement at a minimum. 2 Share this post Link to post Share on other sites
Racinbob 12,844 #7 Posted July 18, 2015 Very true Mike. I would hold it up as well when doing my 800' stone drive. The downforce worked well on the concrete areas and also when I was moving dirt or stones. Share this post Link to post Share on other sites
