mrc 727 #1 Posted July 16, 2015 hi guys, is the pto around the mule drive to deck belt the same for a 42inch SD deck as the 42inch RD deck? thank you mike in mass Share this post Link to post Share on other sites
bmsgaffer 2,043 #2 Posted July 16, 2015 I'm sure someone will be in shortly to give you the proper numbers but no, the belts are different sizes between 42 SD and RD. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,503 #3 Posted July 16, 2015 For the 1977 model long frame tractors like a C-12042" rear discharge model 75-42MR01Drive belt #102741 is 1/2" x 96.6" --- Spindle belt #6738 is 1/2" x 86"42" side discharge model 75-42MS01Drive belt #102742 is 1/2" x 103" --- Spindle belt #1594 is 1/2" x 107.21"Garry 1 Share this post Link to post Share on other sites
