theredhorse 1 #1 Posted July 16, 2015 I have a B111 6 speed with hi and low with the foote 4000-5 rear it would not move so i opened the rear. The bevel gears on the axle are gone and the bevel gears on the cross shaft are also messed up if you have any idea where to get parts new or used that would be much help. Share this post Link to post Share on other sites
groundhog47 448 #2 Posted July 16, 2015 Could you add a picture of gear(s), I've got some unidentified bevel gears, definitely not for WH tran or tiller. 1 Share this post Link to post Share on other sites
stevasaurus 23,712 #3 Posted July 16, 2015 I would check and see what Gerry has 1st, but here is a link that may point you in the right direction... http://www.outdoordistributors.com/dana-foote/dana-foote_search.htmlIf you do a search quite a few threads are out there concerning this transmission. You may have to find a Peerless 669 (which is just a 3 speed...no hi/low) to replace your foote-4000. Just type "b-111 foote" in the search box. Share this post Link to post Share on other sites
