cod 121 #1 Posted July 5, 2015 As it's July 5th, I'm going to try an install an automotive 4 terminal solenoid on my 418-A and see if I can "liberate" myself from having to screw around with the standard replacement solenoids in use today. Actually I'm curious to see if a solenoid with what I assume will have larger components holds up longer.I do have a question though about the wiring as there are two small lugs marked "S" and "I" and I believe I need to connect the wire from the ignition switch to the "S" lug to start the engine. I believe the some of you may have tried this in the past and any information would be greatly appreciated as garage fireworks just don't the same appeal as the ones outside...Thanks - Cod Share this post Link to post Share on other sites
Racinbob 12,297 #2 Posted July 5, 2015 Yes, connect the ignition switch to the 'S' and just ignore the 'I' terminal. 1 Share this post Link to post Share on other sites
cod 121 #3 Posted July 6, 2015 The surgery was successful and the patient lives!!!Thanks for the tip!Cod Share this post Link to post Share on other sites
