Dennys502 246 #1 Posted July 3, 2015 The Solex carb on my D250 started leaking gas past the needle valve a couple of days ago. I decided to make an adapter and put a carb off a Kohler 22hp instead of fixing the solex at this time. I had a carb already which is why I decided on that carb. I will probably order a kit for the solex and rebuild it just in case I ever want to restore it to origional. This is the Adapter I made today. 3 Share this post Link to post Share on other sites
WHX?? 51,837 #2 Posted July 3, 2015 You dirty devil Denny....I thought I saw a milling machine in your shop.... You dirty devil Denny....I thought I saw a milling machine in your shop.... Share this post Link to post Share on other sites
Dennys502 246 #3 Posted July 3, 2015 Yes - that you did. Share this post Link to post Share on other sites
Jolopicus 0 #4 Posted September 14, 2016 Any chance you could post the measurements for that bad boy? throat size, bolt distance/size... Also where did you get that rebuild kit from? I know there is a ton of info on RS, but I'm struggling to find specifics... Thx in advanced! Share this post Link to post Share on other sites
Dennys502 246 #5 Posted September 15, 2016 This is the kit for my carburetor. I'm not sure if yours is the same. I have this modeled up in Autocad - I will get some dimensions for you. http://www.ebay.com/itm/190298742864?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Share this post Link to post Share on other sites
Dennys502 246 #6 Posted September 15, 2016 Here is a rough drawing of it. carb adapter2.bmp Share this post Link to post Share on other sites
Jolopicus 0 #7 Posted September 15, 2016 Denny, thanks so much for this, saving me a lot of time, and I'm sure a few headaches! I hope they ship to the US. Share this post Link to post Share on other sites
wedge 80 #8 Posted September 15, 2016 Great to see another tool and die man in the mix !! Share this post Link to post Share on other sites
Jolopicus 0 #9 Posted September 15, 2016 1 hour ago, wedge said: Great to see another tool and die man in the mix !! I wish i had a good setup, I've gotta go down to the Minnesota Transportation Museum, a place I'm a member of, to do any real milling. That or just 3d print the thing in metal... It's getting pretty cheap these days. Share this post Link to post Share on other sites
