Similar Content
By KP Cool
Hello, Have a C-161 Manual transmission Kohler engine.
I had been mowing a good bit and thought I would wash grass and dirt off it. Well apparently got something wet and now may have shorted something out. After drying out, something is still wrong it tried to start a couple of time, but now nothing, unless I use two jumpers from the switch connector (and I even replaced switch and still have issue). It will start and run and lights will work etc. except with way I have it jumper-ed it won't shut off unless you disconnect the 1st jumper.
To start and keep it running, use two jumper wires from the switch connector (five blade). 1st. jumper wire from the black wire to the positive on the battery and 2nd jumper wire from red wire to positive on the battery to engage the starter to start it. hope that makes sense, see pictures (Note - the amp meter was showing charging even though switch off and even disconnected, so to rule the amp meter I by passed it.). Did the the one relay block get too wet and short out? Other side note, have had some issues with mice and even had a black snake in it this morning, guess it was looking for food. Do not see any wires chewed, and it was running fine until hosed off dirt and grass clippings.
Thoughts or suggestions??
Thanks.
By Hardy6
Hi I recently got an old charger 12 that had been sitting in a friends backyard for at least 20 years. The engine spins over and the starter works but it has no spark, I’ve been looking online for some solutions but I can’t seem to find any other charger 12s with my ignition setup. It seems to have a sort CDI box but I’m not sure. Does anybody know how this works or any tips on how to test for where the problem is ?
By Slightly Discombobulated
I need some help. I picked up a 1968 electro 12 (1-7235) that I'm assuming is an early model built with a leftover 67 engine because the engine patina matches the tractor and it has an external generator/starter instead of the magneto. It's a k301S-4712B. I bought it knowing that the engine turns freely and that it had no spark. Being 52 years old I figured it deserved some fresh ignition parts so I replaced the coil, condenser, points (cleaned and set to .020), spark plug (.035), and plug wire, and I still cannot get a spark at the plug or through my spark plug tester. It turns over okay and I've got 12 volts to the positive terminal on the coil. It's been many years since last worked on this type of ignition system and I'm stumped. I would appreciate any input/suggestions you might have. If it were something newer I'd suspect a safety switch but I can't see that this has any.
By firemanironman
I picked up a wheel horse and I am having trouble finding the connection for this wire. I have no spark and have searched for the placement of this wire within the distance of its length...any ideas?...can't seem to paste the picture....
By John Casadonte
I have a late 90's 269H with the Kohler 17HP motor. After cutting for about 1 hour I turned it off, tried to start it about 10 minutes late and it would not crank. The dash lights turn on (oil, battery, parking brake), I can hear/feel the relay click but the starter will not turn.
All fuses checked All relays checked no broken/frayed wires
Solenoid will not engage when crossing the terminals with a screw driver and key switch in on position. Is this a defacto solenoid issue or do I need to check other things? Also, I am showing that the part number for the solenoid is: 52-435-02. i found one at http://www.milfordpower.com/R12130-Starter-Solenoid-Replaces-Kohler-52-435-02S-p/r12130.htm
Thanks in advance for any direction or advice.
John
