htopjimmy26 3 #1 Posted November 13, 2008 Has anyone done the Small Engine Warenouse 24hp Honda repower? It is available for the 416-520 and probably will fit everthing else too. I just watched a video on Youtube of one of these in a Jd 318 and it sounded like a Man's motor,[The wife can have one too but first I need her permission to buy ]. Share this post Link to post Share on other sites
Nick 13 #2 Posted November 13, 2008 I sold some parts to a local person that said he had been the first D owner to get the swap. I think they did the work for him and used his tractor to put together the parts needed for the "kit". He was happy with the results. Now would I do the swap? If cash wasn't an option then maybe. Its hard for me to say I would do it when thinking of how many nice running tractors that money might buy. I guess Im also not sold on Honda engines. Where do you get parts and service done on a Honda? Have you ever heard the newer Kohlers ? They have a nice rumble. My brother has worked on some tractors with swap kits that came from Small Engine Warehouse. From what I remember one newer conversion needed engine repair that wasnt going to be under warranty and another 520 owner came in trying to get the tach working. It might have had other issues also. I don't think either of those was a Honda engine. Share this post Link to post Share on other sites
FrankinWNY 13 #3 Posted November 13, 2008 :hide: I have a friend that repowered a 520H with a Honda 24HP engine, works great, sounds good and lots of power. He runs a 2 stage snow blower and a 42" rear discharge deck with it. Uses the Carlisle AT101 24x12x12s. He was able to use the original Onan exhaust and motor mounting plate. He also fabricated a foot pedal that rocks for forward and reverse that works so much better than the Wheel Horse assessory, returns to neuteral when you lift your foot. Frank in WNY Share this post Link to post Share on other sites
FrankinWNY 13 #4 Posted November 13, 2008 Pics of WH Honda 24HP conversion and foot control. Frank in WNY http://photobucket.com/WH520HConversion Share this post Link to post Share on other sites
Nick 13 #5 Posted November 13, 2008 Frank, Your friend did some fine work on the 520. That foot control fabrication looks really nice. Forgot I had some pictures of the Kohler we ran on a 520. Never tried to install a pto as it was a dedicated loader tractor. Share this post Link to post Share on other sites
Jim_M 179 #6 Posted November 14, 2008 What am I doing wrong? I can't see Frank's pictures. Share this post Link to post Share on other sites
DMESS 24 #7 Posted November 14, 2008 Jim, step back into the first album. I think it is just titled "Franks album" or something very close to that. Tractor is really impressive. The foot control is sweet and I'm very surprised at how compact the Honda powerplant is. looks like a smaller foot print than the Onan. Share this post Link to post Share on other sites
htopjimmy26 3 #8 Posted November 14, 2008 It's kind of a mystery to me why all I can for for conversion kits for the onans are Hondas or Briggs. That 25hp command looks nice And really is only a few bucks more. Nick, hows the fit of that kohler, it looks kinda tight. Do you think that a guy could make the pto functional and get the hood to shut without to much hackery? Frank did you get to operate that 520 with the Honda? With that 42in deck it's gotta mow as fast as you can drive. My thought are I already own 1 tractor with an onan and probably will someday get a 520h, if I ever lose an engine I probably will repower with something else and thought I'ld get some opinions. :hide: Share this post Link to post Share on other sites
bluetuna08 0 #9 Posted November 14, 2008 with a little egineering you can make one of those 30 horse kohlers fit. I have resolved myself though the a rebuild on the onan if anything happens to it such as bearings or con rod or valve. anything short of the block cracking I would build it up and make a hell of an engine for less than a full engine swap. Share this post Link to post Share on other sites
FrankinWNY 13 #10 Posted November 14, 2008 I have driven my friend's Honda Conversion, your'e right it will mow at 8 MPH, he likes it because of not throwing grass around, wants the mulching kit for it however. I have driven with WHs foot control and his fabrication and there is no comparison, his is smooth and like I stated when you take off your foot it goes to neutral immediately which is a great safety feature. Frank in WNY still trying to get the photo option figured out, did my best. Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,926 #11 Posted November 14, 2008 Frank's pictures - clickless: Share this post Link to post Share on other sites
DMESS 24 #12 Posted November 14, 2008 What type of bearings do these engines have on the pto side of the crank? It is my understanding that Toro switched to the electric clutch on the last few production years because the Command engines couldn't support the thrust load that the old manual PTO setup induced onto the crank. I'm not intimately familiar with them, but aparently they don't have the ball bearings on the PTO side like the K series/Magnums. Something to consider when considering a repower. Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,926 #13 Posted November 14, 2008 Dustin, I'm no expert here, but my '98 314-8, which has the Kohler Command CH-14 on it, has the manual pto like my older C-s have. I think the last 315-8 model no. 73450, which had the Command CH-15, had the electric pto clutch per the parts manual. Hmm, what would be the difference in the CH-14 and the CH-15, that would warrant a switch to the electric clutch. Perhaps to keep these tractors up to date and inline with the rest of the market, or like Dustin states, the Commands couldn't handle the manual ptos? :hide: Share this post Link to post Share on other sites
DMESS 24 #14 Posted November 14, 2008 Dustin, I'm no expert here, but my '98 314-8, which has the Kohler Command CH-14 on it, has the manual pto like my older C-s have. I think the last 315-8 model no. 73450, which had the Command CH-15, had the electric pto clutch per the parts manual. Hmm, what would be the difference in the CH-14 and the CH-15, that would warrant a switch to the electric clutch. Perhaps to keep these tractors up to date and inline with the rest of the market, or like Dustin states, the Commands couldn't handle the manual ptos? As I mentioned, I'm not super familiar with them so I can't offer all of this with 100% certainty. Maybe the switch was more about keeping up with the market, but I'd swear I heard some talk about the thrust load issue. Maybe someone will step in with some more info on this. I have no clue about the differences in the Command engines. :D Share this post Link to post Share on other sites
wh500special 2,453 #15 Posted November 14, 2008 Maybe the switch was more about keeping up with the market, but I'd swear I heard some talk about the thrust load issue. I know some engines cannot handle the end load from the PTO (Briggs in particular), but I think the reason Toro switched to electric PTO clutches was because they offer better braking than the manual version. There are some OPEI/ANSI laws that require the driven mower to stop motion within so many seconds after being shut down, and the electric clutches apparently meet that goal more readily and don't require the same adjustments as the manual assembly. I'm sure there are assembly issues too...It's a lot faster to slip an electric clutch on the crankshaft than to assemble the mounting plates, brake, bail, clips, etc on he manual version. That 24 Honda in a C195 would be a nice setup, dontcha think? I've never personally used a big Honda, but I have heard nothing but good things about them. Honda engines, generally, are lauded as being the best running engines out there. My only personal experience with a Honda is a 5.5 hp one on dad's pressure washer and my opinions have been mixed since the thing was new. It runs wonderfully and sounds great, very smooth for a single cylinder. But it is one of the hardest engines to start we have ever had. It's been in to the shop too under warranty and nothing was found to be wrong, but they agreed it is hard starting (takes 10 or more pulls to get going). Great engine otherwise though and its stubbornness seems to be an anomaly. Even with this unique issue, I'd buy another one. Steve Share this post Link to post Share on other sites
wh500special 2,453 #16 Posted November 14, 2008 I also forgot to mention the "KeyChoice" mow-in-reverse protection Toro put on the later tractors. New regs or common protocol in the lawn and garden world make the mower deck shut down when the operator shifts to reverse for safety. I think an electric clutch is probably the only was to acheived that safety feature. A second key switch on the Toro tractors allows you to bypass the MIR protection and was dubbed "KeyChoice" by the marketing guys. Steve Share this post Link to post Share on other sites
htopjimmy26 3 #17 Posted November 15, 2008 Regarding the foot control; it sure looks like that feller swiped that pedal assembly off of something, any idea what? Share this post Link to post Share on other sites
84 400 0 #18 Posted November 15, 2008 I can say from personal experience that the honda motors are pretty good. I work at a rental shop and the hondas are on all our new stuff and are the replacement motor of choice. These see alot of hours and although we maintain them joe contractor or the home owner really can take a tole on them. We are running the larger versions on our hydrolic post hole diggers and stump grinder. Again very reliable engines infarct some only have a recoil start on them. I will say that B&S have gone to complete crap. They do not run as smooth and are no where near as reliable. I am not a fan of them at all . There older motors where good but quality has dropped. I would have to say that robin,wisconson, honda, kohler, are about the best around IMO. Aside from regular oil changes the hondas only see air filter and spark plug changes and have served us very well. We have lost a few but overall I am impressed with them. If it was my tractor though I would go Kohler. Ditch Witch whom we buy equipment from uses both honda and kohler engines. Our mini track loader and pipe puller both have kohler power plants. They seem to make the best power and really preform well. One funny thing is that after running em around the kohlers always seem to give off a backfire after turning them off. I can turn one off walking away and know exactly when I will here that loud "pop"! Share this post Link to post Share on other sites
Curmudgeon 28 #19 Posted November 16, 2008 Interesting thread. If I could have afforded it, I would have put one in the 520 pictured on their website under 520H Repower. Seriously, that's my ex tractor, on my ex lawn, in front of the ex house. (Notice the barbell rear wheel weights) I've had a few Honda engines, all were reliable, smooth, easy to start, etc. The only american engine to come close to their quality, in my opinion, is the K-Series Kohler. Share this post Link to post Share on other sites
