bigbear 0 #1 Posted June 27, 2015 I have a 252H Wheel Horse with a 42inch rear discharge mower deck. I bought it used. From the lift assembly on the tractor to the mower deck there is a piece of metric all-thread. I am trying to find a picture of the real lift arm or a source for one. I can probably fabricate one if I could see it.Thanksbigbear Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,014 #2 Posted June 27, 2015 Here is the one listed for your tractorhttp://www.wheelhorseforum.com/files/file/3105-mower-rotary-42in-rd-1988-1989-05-42rk01-tiplpdf/Garry Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,014 #3 Posted June 29, 2015 (edited) Perhaps what you are looking for is part of the tractor lift illustrated in the parts listhttp://www.wheelhorseforum.com/files/file/4342-tractor-1988-252-h-da-tiplpdf/Item #26 has been discontinued at Toro.Item #14 is a 1/2" SAE flat washer so the link should be made of 1/2" round bar.Garry Edited June 29, 2015 by gwest_ca Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,014 #4 Posted June 30, 2015 The lift for the deck should be part of the mower deck and shown in the parts list. There is a trunnion on the cable and that must be the lifting point. This service bulletin describes modifying an older deck to fit this application and the cable is called a lift cable.http://www.wheelhorseforum.com/files/file/3923-wh61-90-416-b-series-mowers-converted-to-250-seriespdf/This bulletin lists the cables for each applicationhttp://www.wheelhorseforum.com/files/file/3872-wh61-90-334-mower-leveling-cables-a-b-lt-rr-seriespdf/Garry Share this post Link to post Share on other sites
