Brian01 481 #1 Posted June 25, 2015 Well brought her home just under a week ago. 1 Share this post Link to post Share on other sites
Brian01 481 #3 Posted June 25, 2015 Here it is as of today.... 3 Share this post Link to post Share on other sites
Brian01 481 #4 Posted June 25, 2015 Working on painting engine tins and what not today. Share this post Link to post Share on other sites
Brian01 481 #5 Posted June 25, 2015 Just so the dull motor will match the rest of the freshened tractor...or that's the plan anywho Share this post Link to post Share on other sites
AMC RULES 37,196 #6 Posted June 25, 2015 Some really nice work... night & day difference. Share this post Link to post Share on other sites
Brian01 481 #9 Posted June 26, 2015 Had to drill one of the bolts out in the mesh that covers the shroud..broke off when I went to take it off...but drilled out okay and new bolt went in OK...thankfully Share this post Link to post Share on other sites
Brian01 481 #10 Posted June 26, 2015 Also had to tinker with the throttle...kept going back in to idle...its a little better now but not up to par...any ideas? Would be appreciated Share this post Link to post Share on other sites
Brian01 481 #11 Posted June 26, 2015 Painting gas tank and clamp...God only knows how long it'll take to dry....pouring down rain outside now...frekin humidity Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,472 #12 Posted June 26, 2015 (edited) Also had to tinker with the throttle...kept going back in to idle...its a little better now but not up to par...any ideas? Would be appreciated You can try to pinch the rivet tighter in the throttle control. The pivot has to be tight enough to overcome the governor spring tension plus the pull the governor develops when it is working.I remove the rivet and replace it with about a 1-1/2" long bolt. Using a long bolt gives you about 1/4"-5/16" of bolt shaft that is not threaded and that is where the lever and bracket ride so they do not ride on bolt threads and wear. Shim as necessary with flat washers and add a Nyloc nut. Cut of the extra threads. Put it back together and you can reach in with 2 wrenches and adjust to the tension that is required to hold it with the engine running.Garry Edited June 27, 2015 by gwest_ca Share this post Link to post Share on other sites
Brian01 481 #13 Posted June 26, 2015 OK thanks....gas tank turned out like crap, I'll have to redo it, "one of these days" Share this post Link to post Share on other sites
Brian01 481 #14 Posted June 26, 2015 I did get fuel filter out on though....didn't have one at all before. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,472 #18 Posted June 29, 2015 Is your serial number 469894?Garry Share this post Link to post Share on other sites
Trouty56 567 #19 Posted June 29, 2015 You can get decals for the dash and where the direction indicator plate is....that is if you like..... Share this post Link to post Share on other sites
Brian01 481 #20 Posted June 29, 2015 Is your serial number 469894?Garry Yes Share this post Link to post Share on other sites
Brian01 481 #21 Posted June 29, 2015 You can get decals for the dash and where the direction indicator plate is....that is if you like..... Yeah I know , just experimenting at the moment Share this post Link to post Share on other sites
Brian01 481 #22 Posted June 29, 2015 I liked the wire at first, now not even a day later I'm having second thoughts lol Share this post Link to post Share on other sites
Brian01 481 #23 Posted June 29, 2015 White not wire Share this post Link to post Share on other sites
Trouty56 567 #24 Posted June 29, 2015 White not wire I liked the wire at first, now not even a day later I'm having second thoughts lol Let me take a pic of what the decals look like.... Share this post Link to post Share on other sites
Trouty56 567 #25 Posted June 29, 2015 Look sideways at it....lol Share this post Link to post Share on other sites
