mowerman1193
Mower Blades?? SD Vs. RD?
mowerman1193
I have most experience with the rear discharge decks.. Then I added one of those mulch plates a few years ago to my rear discharge deck and the blades was wider.. like 2" wide rather than the Rear discharge desk 1- 3/4 ish blades.. Anyway now I am using a side discharge deck.. and needs new blades. Does anyone know if the RD and SD blades are the same? I was always under the impression that they was different since years ago there were talks of the gator blades not being available for the RD but was for the SD decks.. But looking up in the parts viewer the only number I find for blades for the 42" decks is the same number 106636.. If the RD blades work then I don't need to buy blades as I have 2 new sets from before I installed that mulch plate in the RD deck..
So school me on the 42" decks guys.. I aways have a hard time finding the correct parts because the manuals I look in cover both RD and SD and somehow I end up with the wrong part, LOL
If it matters we are talking 1984 era decks and tractors..
Thanks,
Kevin
gwest_ca
1984 42" rear discharge model 05-42MR02 uses blade set 106635
1984 42" side discharge model 05-42MS03 uses blade set 106636
Mower blade chart
http://www.wheelhorseforum.com/files/file/675-chart-blades-and-spindle-cups-rotary-mower-15-pages-492-0392pdf/
Garry
mowerman1193
Awesome!! Thank you for the link.. didn't know it was on here..
doc724
As I recall, the difference in the blades was the "lift" (the bend on the wing at the end).  Side discharge needed the high lift blades.  RD could use the low lift blades.  I have used high lift RD's without problem.
PaulC
The difference is the length of the blade, the RD decks use a 14 1/2 inch blade and the SD use a 13 7/8 long blade. The extra length of the RD blades on a SD deck will cause interference issues, blades potentially hitting each other and the deck. I had a set of RD blades I didn't need anymore so I cut a little off of each end and used them on my SD, I would highly recommend having a good way to balance them after if you do this. Although after I started balancing my blades I recommend that to anyone for any blades that you sharpen yourself.
There is a direct replacement gator blade for the SD, Oregon 90-643. There is the proper size gator blade available for the RD but it comes with a 11/16" hole instead of 3/4" so some guys have bought those and opened the hole up, Oregon 96-303. Also what I have saw others do and plan to try myself next time I mow is put the 90-643 gator blade on top of the standard RD blade in a "X" pattern and mow that way.
gwest_ca
Someone asked Oregon once why they did not have a Gator blade for a very popular application. The answer was the Gator was not an improvement over the OEM blade so they never made one.
Garry
mowerman1193
Back in the late 1980's I used to run 6 blades ( 2 each spindle ) on my RD deck to help mulch up the grass better.. worked pretty good too.. I had not even put the two separate blades together to see if they are different.. but I guess if I had I could have answered part of my own question as one is longer than the other...
PaulC
Ok I did end up doing the "X" pattern with both sets of blades and wasn't at all happy with the outcome. Grass did grow like crazy this week so it was thick but the clumping was just as bad as before. The SD decks do great until you make it to the last few passes in the middle and then all your clumps are right there.
skrusins
I have a 42"RD recycle with the insides taken out and a 48"SD both have 6 blades on each.
I've used them for over 2 seasons without any problems actually it creates a better lift.
I then put 6 blades on my 60"SD Kubota zero WOW what a difference. Sounded like a wind tunnel.
