muz123 1,193 #1 Posted June 17, 2015 (edited) Will this fit my 520? Its on eBay for $450. Thanks, Dave Edited June 17, 2015 by muz123 Share this post Link to post Share on other sites
Butch 194 #2 Posted June 17, 2015 (edited) No. You need one that mounts to your rear axle with a rear axle mount kit. The axle mount runsaround $50 used on Ebay and about $300 or so for the plow. It's a great attachment. The plow youneed will also have a lever on the right side to tilt the blade from the drivers seat. Edited June 17, 2015 by Butch 1 Share this post Link to post Share on other sites
Butch 194 #3 Posted June 17, 2015 You want something like this.Look for that manual in the manual section. It's on page 6 under plows. Blade Grader Pushed 50in 1993-1994 79351 OM IPL.pdf 2 Share this post Link to post Share on other sites
AMC RULES 37,237 #4 Posted June 17, 2015 Then, you'll need the correct lift link for your tractor. 1 Share this post Link to post Share on other sites
Racinbob 12,275 #5 Posted June 17, 2015 That will work muz123 but it's not the one they listed for a 520. I used that same model for years on a couple of C-series (same attachment mounting). That simply hooks to the mid mount and connects to the lift. I used a rod direct to the lift bar rock shaft and not the lift bar. That way I could 'power' down. I also welded a bar on the front of it so it would connect to the rear slot hitch. It's simplistic compared to the model Butch is referring to but it works well. 2 Share this post Link to post Share on other sites
Racinbob 12,275 #6 Posted June 17, 2015 By the way Dave, personally I think that Ebay price is way out of line. 2 Share this post Link to post Share on other sites
dcrage 631 #7 Posted June 17, 2015 For what it is worth, I bought that unit a couple of years ago for $125 off CL here in MO. Share this post Link to post Share on other sites
Racinbob 12,275 #8 Posted June 17, 2015 That's much more like it. Share this post Link to post Share on other sites
Forest Road 594 #9 Posted June 17, 2015 That's the old style. It'll work. Personally I prefer the newer style which mounts to the rear axle. By mounting to the axle it takes all stress off chassis. By far my favorite attachment. Cleans up our 1/4 mile driveway a few times a year. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Tankman 3,523 #10 Posted June 17, 2015 I like the mid-mount grader. Does a great job on my 100 yard gravel driveway. 1 Share this post Link to post Share on other sites
857 horse 2,588 #11 Posted June 17, 2015 will the newer grader blade fit the older WH tractors?? 1 Share this post Link to post Share on other sites
Racinbob 12,275 #12 Posted June 17, 2015 Yes. But watch the wheelbase. I'm not sure about the clearance on a short wheelbase tractor. The old style doesn't care about the wheelbase. Share this post Link to post Share on other sites
857 horse 2,588 #13 Posted June 17, 2015 thanks bob............an 857 short frame....i wouldnt mind a rear mount blade Share this post Link to post Share on other sites
wheeledhorseman 579 #14 Posted June 17, 2015 Will this fit my 520? Its on eBay for $450. Thanks, Dave $450 Yer 'avin a giraffe, mate!(Cockney rhyming slang, giraffe = laugh, so a way of conveying to the vendor that his price is unreasonable)Mid-mount graders are very rare and hard to come by here in the UK but even so I got mine for half that price!Andy 1 Share this post Link to post Share on other sites
Racinbob 12,275 #15 Posted June 17, 2015 You might find that the newer blades will work fine on a short tractora rear . I'm just not sure. I liked having my oldy adapted to work as as a rear blade but I couldn't 'power' it down like I could as a mid-mount. Share this post Link to post Share on other sites
muz123 1,193 #16 Posted June 17, 2015 Thanks for all the info guys! I will try and find a newer grader blade. Share this post Link to post Share on other sites
