rickinmemphis 1 #1 Posted June 16, 2015 (edited) I have not found any info on the open ended needle bearings that ride on the engine shaft bushing in the Manual PTO. Do they run Dry or do they need a drop of oil now and again? The outer thrust bearing is sealed and should need nothing. Edited June 16, 2015 by rickinmemphis Share this post Link to post Share on other sites
slammer302 2,157 #2 Posted June 16, 2015 i use a little bit of high temp grease you have to becareful not to use to much or it will sling out all over your clutch disc and cause it to slip Share this post Link to post Share on other sites
