muz123 1,193 #1 Posted June 13, 2015 (edited) Im trying to hook up my tiller to my 312-H and whenever i try and put the tiller lift cable through the tube it gets stuck. I blew it out and got all of the dust outand still gets stuck. Any ideas on how to hook it up?How to fix? I noticed the tube is the same as on my 520-H and the cable will go through that. Maybe the tube is to narrow?Thanks, Dave Edited June 13, 2015 by muz123 Share this post Link to post Share on other sites
KC9KAS 4,746 #2 Posted June 13, 2015 Does it get stuck at the same spot each time you try to push it through?Is the tube mashed/bent?Try a coat hanger straightened out and see if it will push through.. 1 Share this post Link to post Share on other sites
muz123 1,193 #3 Posted June 13, 2015 (edited) Does it get stuck at the same spot each time you try to push it through?Is the tube mashed/bent?Try a coat hanger straightened out and see if it will push through.. I did try the coat hanger trick. It appears the cable to big is to make it through the bend or its not stiff enough? Edited June 13, 2015 by muz123 Share this post Link to post Share on other sites
KC9KAS 4,746 #4 Posted June 13, 2015 Try a little tape on the cable end if it is frayed...maybe a little WD-40 sprayed into the tube... 1 Share this post Link to post Share on other sites
muz123 1,193 #5 Posted June 13, 2015 Try a little tape on the cable end if it is frayed...maybe a little WD-40 sprayed into the tube... I'll have to give that a try, maybe the WD-40 will do the trick! Thanks for the reply! Share this post Link to post Share on other sites
BESTDOGEVER 218 #6 Posted June 14, 2015 If you have an old throttle or choke cable sometimes you can use that like a snaketo clear what ever is blocking is 2 Share this post Link to post Share on other sites
dennist 139 #7 Posted June 14, 2015 I had one that had a similar issue, but when I removed the tube it had worn through at the bend and the ball of the cable would get stuck there. Share this post Link to post Share on other sites
muz123 1,193 #8 Posted June 14, 2015 I had one that had a similar issue, but when I removed the tube it had worn through at the bend and the ball of the cable would get stuck there. I can't get it through both bends, how hard is it to remove the tube? Share this post Link to post Share on other sites
dennist 139 #9 Posted June 14, 2015 I had one that had a similar issue, but when I removed the tube it had worn through at the bend and the ball of the cable would get stuck there. I can't get it through both bends, how hard is it to remove the tube? Well, that's kinda hard to answer.....if you have no build up of crud under the pump then it is not too bad most of times, BUT I have had a few that have fought me for quite a bit. I use a screw driver and just keep rocking it side to side. 1 Share this post Link to post Share on other sites
muz123 1,193 #10 Posted June 14, 2015 I may just use another tractor to till with, but first I'll try WD40. Share this post Link to post Share on other sites
Wheel-N-It 2,978 #11 Posted June 14, 2015 If you have an electrician friend borrow his fish tape and try to clear the obstruction with that. You could have some kind of insect nest in there. Share this post Link to post Share on other sites
WNYPCRepair 1,924 #12 Posted June 14, 2015 Harbor Freight sells a cheap nylon fish tape that may work Share this post Link to post Share on other sites
Wheel-N-It 2,978 #13 Posted June 14, 2015 Harbor Freight sells a cheap nylon fish tape that may work Nylon may work, however the steel tape can be sharpened to dig out a hard packed nest of dirt. Here where I live we have these wasp like things nicknamed "Mud Dobbers" Those things will build a nest in the most unexpected places such as a empty tube under the fender pan of a wheel horse. 1 Share this post Link to post Share on other sites
KC9KAS 4,746 #14 Posted June 14, 2015 If you have an air compressor, try blasting air through the tube...at least this will help you figure out if the tube is blocked or not.I have tried to "fish" wires through automobile/truck floor boards, frames, headliners and door posts, and some will fight you all the way!I have run coat hangers through one way, tied a string on and pulled it back and then tied the wire onto the string to pull it through! You have to "outsmart" the problem! 3 Share this post Link to post Share on other sites
