snowhound 106 #1 Posted June 8, 2015 I am going to look at a C 160 with a hydro and know nothing about the hydro transmission. The tractor isn't running so if I do buy it I will have to roll it onto my truck I know there should be a bypass valve but don't know where to look for it. Could someone tell me where to look or post a photo of the valve.Ed Share this post Link to post Share on other sites
oldredrider 2,553 #2 Posted June 8, 2015 (edited) I don't have a picture, but the tow valve is on the left side of the transmission behind the fender pan facing forward. Should be a slotted bolt for a screwdriver. Edited June 8, 2015 by oldredrider 2 Share this post Link to post Share on other sites
chorusguy 227 #3 Posted June 8, 2015 I recently bought one that had been sitting for a while. It rolled easily without turning the tow valve. I thought I was screwed but when I got it home and got it started it functioned fine. Someone on the forum said that after they sit for a while the hydro loses pressure and that is why it rolled. The tow valve is o the drivers left inside the fender and maybe three inches higher than the fender lip. It is about the diameter of a pencil and protrudes about an inch 1 Share this post Link to post Share on other sites
boovuc 1,090 #4 Posted June 8, 2015 I would still try to open the tow valve before moving. If it sat awhile and the tow valve hasn't been opened in a good long while, it may be a (edit) to open. Bring tools. You can move it very slowly for a short distance but a great distance it isn't advisable. 1 Share this post Link to post Share on other sites
snowhound 106 #5 Posted June 8, 2015 Thanks for the replies, I will bring a dolly to but the rear wheels on just in case I have a problem with the tow valve. Share this post Link to post Share on other sites
daveoman1966 3,880 #6 Posted June 8, 2015 Tow valve is on left side, here is a bad pic of it...but you can see the location, at least. It is difficult to get to and probably stuck. 1 Share this post Link to post Share on other sites
snowhound 106 #7 Posted June 8, 2015 Thanks for the photos Dave Share this post Link to post Share on other sites
Wheelhorsegt14 1 #8 Posted March 10, 2017 What is the correct position for the push valve? Share this post Link to post Share on other sites
daveoman1966 3,880 #9 Posted March 10, 2017 To close the PUSH valve, turn it all all the way CLOCKWISE, until it bottoms out. Share this post Link to post Share on other sites
