prondzy 3,889 #1 Posted June 7, 2015 Does anyone know of a source for the 953 tie rod ends or ball joints that goes from the ross steering gear to the front spindle? I have the rod but my ends are getting real sloppy. any help is greatly appreciated. Share this post Link to post Share on other sites
953 nut 64,255 #2 Posted June 8, 2015 (edited) I had that same problem on one of my 953s a few years ago. I picked up a couple of 1/2" fine thread steering ball joints from Agri Supply (part number 45-114).I put them along side the drag link to decide where to cut the ends off, after cutting I ground them down to about 1/2" diameter than threaded them to 1/2-20 and screwed the new ends on. I had to put a small spot of weld on the end of the shaft that goes to the steering gear to keep it tight and in the proper alignment, the other end that goes to the pittman arm I just tightened in the correct position. I wasn't a member here at the time so I didn't take any pictures.Hope this helps. Edited June 8, 2015 by 953 nut Share this post Link to post Share on other sites
KC9KAS 4,746 #3 Posted June 9, 2015 Try here....http://www.mcmaster.com/#end-links/=xjhcpc Share this post Link to post Share on other sites
prondzy 3,889 #4 Posted June 9, 2015 thanks for the link, does anyone know what the internal thread dimensions are?? Share this post Link to post Share on other sites
