dgjks6 8 #1 Posted June 6, 2015 so I just bought a 37 inch deck. The one I had before had the double v mule drive and six sided belt. This one has a regular belt and mule drive. It looks like the two front pulleys on the deck were changed. They were both flat. We hooked up the deck and it worked. The guy said it came this way. Did they change the set up? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,462 #2 Posted June 6, 2015 Six-sided belthttp://www.wheelhorseforum.com/files/file/1894-mower-rotary-37in-sd-1986-1990-05-37sc01-ipl-810407r1pdf/Regular 4-sided belthttp://www.wheelhorseforum.com/files/file/2994-mower-rotary-37in-sd-1990-05-37sc02-tiplpdf/Garry Share this post Link to post Share on other sites
dcrage 636 #3 Posted June 7, 2015 You should have one flat pulley and one V pulley on the mule drive. Share this post Link to post Share on other sites
TIMOTHY McCLELLAN 12 #4 Posted May 2, 2016 is it a 36 in belt on the 310-8 RD deck or 37 " ? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,462 #5 Posted May 2, 2016 Two models of 36" deck can be rear discharge or side discharge and have 3 blades. 37" is side discharge only and has 2 blades. Garry Share this post Link to post Share on other sites
TIMOTHY McCLELLAN 12 #6 Posted May 4, 2016 THANK YOU FOR ALL THE GOOD INFORMATION !!!!!!! Share this post Link to post Share on other sites
