Geochurchi 3 #1 Posted June 6, 2015 Hi All, what is the correct part number for blades on an 13-38 XL mower ? My machine will not through grass into the chute and I am wondering if the blades are the right ones.ThanksGeo Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,510 #2 Posted June 6, 2015 What is the model number of your tractor and it's serial number?Models 71185, 71190, 71205 and 71208.There are at least 2 different blades.Garry Share this post Link to post Share on other sites
Geochurchi 3 #3 Posted June 6, 2015 Hi, the model # 13-38 XL and the serial # is 6905222.Thanks for the reply.Geo Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,510 #4 Posted June 6, 2015 The serial number tells us it is a 1996 model. On the same ID decal there should be a model number 71185 or 71205 and they use different blades.Model 71185 came with a recycler deck and uses blade number 79-3061 - 2 requiredModel 71205 came with a side discharge deck and uses blade number 57-4700 - 2 requiredMentioned the quantity because some blades come in a set and you order 1 set.Blades are listed as being 19.32" long which should be the diagonal length tip to tip.Post the model number when you find it and will try to link you to the correct manuals.Garry Share this post Link to post Share on other sites
Geochurchi 3 #5 Posted June 7, 2015 OK, Thanks I will check that in a day or 2.geo Share this post Link to post Share on other sites
Geochurchi 3 #6 Posted June 7, 2015 OK, so the model number is a 71185 and I see what the blade number should be from a previous post,so I will check and see what blades are on there.Thanks for the replies.Geo Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,510 #7 Posted June 7, 2015 Here are the manuals I can find for your 1996 model 71185http://www.wheelhorseforum.com/files/file/4683-tractor-1996-13-38xl-da-om-ipl-wiringpdf/Garry Share this post Link to post Share on other sites
